anyone done a head gasket please help
does anyone know what oil control jet/oil orifice looks like. doing my head gasket,and think i lost mine!!!! it is located between cyl 2/3 in the teardrop shaped hole. haynes mentions not to lose the oil control jet. can't find mine, and can't find pics of it anywhere. there is a piece of steel pressed in the block but i don't think this is it.
acura dealer can get it (8$) but don't order it if i don't need it and don't wanna put it back together if i do this is a d16 dohc but i think the b16 will be similar
please help!!!!!!!!!!!!!!!!!!
i couldn't find it at that site looked under 99 civic si(closest arcitecture) this is an acura engine
i found this
oil control orifice valve:
A valve located in the feed line between cylinder and cylinder head
here http://www.100megsfree4.com/di...o.htm
this is what i think it is
i just need a description of it to be sure it isn't the steel piece in the block.
i found this
a b16 is a civic motor. go to http://www.acuraautomotiveparts.org if you have a b18. when you say d16 dohc, do you mean zc ?
acmoc
14
Dec 15, 2010 08:03 AM
dmingis
May 4, 2009 07:10 AM
