98 teg, taking out radiator supports
Old Mar 1, 2005 | 11:51 AM
Cielmerlion's Avatar
Default 98 teg, taking out radiator supports
how do you take off the radiator support to an integra, i need to replace them, but havent been eable to get them off
Old Mar 1, 2005 | 01:11 PM
LSvtec03's Avatar
Default Re: 98 teg, taking out radiator supports (Cielmerlion)
drill out the spot welds.
Old Mar 1, 2005 | 02:48 PM
phokindronkin's Avatar
Are you talking about the entire radiator support frame? or just the radiator support brackets? if the whole frame needs replacing, such as from an accident or a JDM conversion, then you will need to drill out the spot welds like LSVtec03 said. I'd suggest looking up MASE's writeup on the JDM conversion, as it really helped me locate all the spot welds on the support frame when i got in my accident.
If you just need to replace the brackets or the radiator, just remove the bolts securing them to the support frame, and lift upwards.
jsk62
Aug 21, 2010 07:40 PM
JDM EJ1 95
Dec 28, 2004 10:39 AM
ev0luti0n
Apr 18, 2004 08:41 AM
B18CYAAA
Jul 14, 2003 03:22 PM
