bearing may be going out........
Old Mar 1, 2005 | 10:50 AM
boostedeghatch's Avatar
Default bearing may be going out........
i think my friend is on the verge of spinning a bearing. he wants to replace all the bearing, main and rod bearings, is there anything else that he needs to replace.
if the crank needs to be micropolished, he will get that done.
i was thinking he will need:
head gasket
maybe:
new rings
what do ya'll suggest for him?
thanks
Old Mar 1, 2005 | 03:20 PM
Blind-Fashion's Avatar
how do you think he is on the verge of spinning a bearing? please elaborate.
Old Mar 1, 2005 | 08:48 PM
onepoint6i's Avatar
Default Re: (Blind Fashion)
how do you know if he's on the verge of spinning a bearing...If you hear noise its ruined already...=new crank....micropolishing is out of the question..
Old Mar 1, 2005 | 08:59 PM
Default Re: bearing may be going out........ (boostedeghatch)
https://honda-tech.com/zerothre...54787
Old Mar 1, 2005 | 09:11 PM
lemongreenhatch's Avatar
ur missing the big facter here oil pump
Old Mar 1, 2005 | 10:57 PM
hondaeg8's Avatar
Default Re: bearing may be going out........ (poorman's-allmotor)
any way he can check if its the oil pump?
Old Mar 1, 2005 | 10:59 PM
Default Re: bearing may be going out........ (hondaeg8)
yea hook up a oil pressure gauge and see what his psi is
Old Mar 1, 2005 | 11:09 PM
its at about 18psi at idle. he checked it yesterday. i think he's going to drop the oil pan tomorrow.
when he turned it on, the oil light didn't come on anymore. he didn't drive it, just turned the car on and let it idle for a bit, then turned it off.
Old Mar 1, 2005 | 11:19 PM
yea when the oil light comes on the oils psi is low i belive idle psi is suposed to be 40-50 so he might have a bad oil pump
Old Mar 2, 2005 | 12:55 AM
idle psi at 40-50psi....ha...thats way too high.
your at 50psi when your cruising i believe.
idle should be about 15-19psi i think.
he drained the oil and you can see some little copperish glitter in the oil.
Old Mar 2, 2005 | 04:25 AM
IN VTEC's Avatar
Maybe it's a thrust bearing or two.
Old Mar 2, 2005 | 08:15 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeghatch &raquo;</TD></TR><TR><TD CLASS="quote">idle psi at 40-50psi....ha...thats way too high.
he drained the oil and you can see some little copperish glitter in the oil.</TD></TR></TABLE>
Copper glitter would be a good sign of bearing wear. But even if he replaced the bearings, is there a bigger problem?
Old Mar 2, 2005 | 08:36 AM
my ls/vtec idled at 45 psi.
Old Mar 2, 2005 | 08:57 AM
LSVTEC 91 Civic's Avatar
Banned
What motor is he working with? 18PSI at idle is fine. If there is no metal in the oil you're good.
Old Mar 2, 2005 | 11:07 AM
my gsr was at 100psi when drvin
Old Mar 2, 2005 | 12:55 PM
its a gsr motor and my post above states he found copper glitter looking stuff.
a bigger problem, i don't think so. motor isn't knocking or anything. the motor sounds fine when you turn it on. you would never think there is anything wrong with it.
he plans on replacing the rod and main bearings, have all the clearances checked, piston rings changed.
B18CivicHatch
Sep 28, 2007 08:38 PM
blkrex
Oct 4, 2006 09:23 AM
94-integra-ls
May 8, 2006 03:37 PM
boostedeghatch
Feb 28, 2005 09:54 PM
dustin
Oct 23, 2002 12:06 PM
