Electric Shock Closing Door
Old Mar 1, 2005 | 10:02 AM
hotstuffjsn's Avatar
Default Electric Shock Closing Door
After driving my lude for awhile, and then stepping out of it, as soon as I grab the outside of the door to close it, I get a mild electric shock. I've noticed this happens quite frequently, is there anything I can do to prevent this?
Old Mar 1, 2005 | 10:20 AM
kulrevon's Avatar
Default Re: Electric Shock Closing Door (hotstuffjsn)
is it more then just static? I get a static shock from my lude during the winter but I didnt think anything of it.
Old Mar 1, 2005 | 11:21 AM
Daemione's Avatar
Default Re: Electric Shock Closing Door (kulrevon)
Hold onto something metal as you're sliding out of the seat. That'll ground you so you don't build up an electric charge from the static.
Old Mar 1, 2005 | 11:39 AM
Greyout's Avatar
Default Re: Electric Shock Closing Door (Daemione)
the car builds up a negative charge as you drive from fricton w/ the air, tires, etc. This charge is stronger when the air is cold & dry (less moisture in the air.)
When you get out and touch the car, you provide a way for the static electricity to get from the body of the car to the ground. So touching something metal in the car before you get out won't help... that doesn't ground you... you aren't providing a ground for the static electricty to discharge until you touch the ground
Try closing the door with your forearm or elbow. The reason you can feel it normally is because the static jump is concentrated on your finger tip, which is A) a small area and B) a sensitive area.
If you use a less sensitive, bigger area, you probably won't notice it, or if you do, you'll barely feel it. so when you get out, just give the door a shove with your forearm, ***, etc.
at least thats my theory
Old Mar 1, 2005 | 11:56 AM
rjr162's Avatar
Default Re: Electric Shock Closing Door (Greyout)
or do as I do, and hold your key in your fingers and touch it to the lock cylinder before you grab the door, this way the spark is between the key and the door... you're not involved.
Old Mar 1, 2005 | 08:07 PM
Default Re: Electric Shock Closing Door (rjr162)
Great ideas everyone! I'm going to try a few of them out to see which works best. Thank you for the input.
Old Mar 1, 2005 | 08:15 PM
cpforyou's Avatar
make sure you have a ballon nearby... rub it on your hair a few times before you exit the car..
Siouxbie
Jan 4, 2019 12:30 PM
P_Dink
Oct 4, 2009 06:30 PM
reno96teg
Jun 22, 2006 04:55 AM
ItalynStylion
Dec 25, 2004 10:06 AM
tsdenny
Oct 13, 2004 07:01 PM
