stalls on first 2-3 starts, but then starts & idles fine?
Old Mar 1, 2005 | 09:58 AM
crxaddikt's Avatar
Default stalls on first 2-3 starts, but then starts & idles fine?
i know that i can troubleshoot this when i get home or sometime later but just it always helps to throw it up on HT to just see peoples opinions, cause sometimes someone had the same thing happen and gives you a reply on what exactly it is, so...........
basically i have zc dohc in 90 crx si with pm6 ecu, brand new fuel filter, good battery, timing has been advanced for several months, everythings in pretty decent shape cause i have had the zc about 2 yrs now and its started instantly every morning, and i have'nt had problems with anything so far, but just the last two days i go to start it and rpm drops and stalls real fast, and then i try a couple more times and it starts on like the 4th time or so and just idles at a good 850rpm smoothly, and i have had a code 1 recently for 02 sensor but it goes away off and on and that was even before it stalled.
any ideas on what it could be? or what i can check? thanks
Old Mar 1, 2005 | 11:08 AM
crxaddikt's Avatar
Default Re: stalls on first 2-3 starts, but then starts & idles fine? (crxaddikt)
i'm pretty sure people skip this post cause its so common, but i did search and the thing is most of the posts people have some turbo, b18, etc... and does'nt apply to mine, so thats why i made my own post instead of searching, so people can tell me what to try depending on my setup which is just a 90 si w/zc
nobody has had this happen?
ghettoda9
Mar 1, 2012 04:27 PM
dohczcrex
Jun 10, 2007 07:20 AM
mr_valentino20032000
Feb 2, 2005 05:17 PM
zexdrex
Sep 14, 2003 03:54 PM
crxdevelop
13
Mar 11, 2003 10:32 AM
