p1300 and misfire codes for all 4 cylinders
Old Mar 1, 2005 | 09:07 AM
lowbudgetracing's Avatar
Default p1300 and misfire codes for all 4 cylinders
hi all i got a 96 obdII gsr all stock except for a dc header
the car runs fine you cant hear or feal any misfire or bad running but after i clear my codes if i drive my car for about 8 miles the check engine light comes on with these five codes p1300, po301,po302,po303,po304
i have new ngk plugs new autolite wires new cap and rotor and new distributor from auto zone
any one have this happen before?thanks
Old Mar 1, 2005 | 09:17 AM
EE_Chris's Avatar
Default Re: p1300 and misfire codes for all 4 cylinders (lowbudgetracing)
Did you just install those components and the misfire started to happen - or did you throw those components at the misfire problem in order to fix it?
Old Mar 1, 2005 | 09:24 AM
this might help i bought the car with a bad motor this new motor did not have a crank speed flucuation sensor so i wired that input to the ckp circut on the distributor
when i first drove the the car it would cut out while driving the tach neddle would bounce thought it was a bad distributor but turned out to be a bad ground now car runs great but i get these codes like clockwork
Old Mar 1, 2005 | 09:32 AM
EE_Chris's Avatar
Why did you think it would be correct to wire the CKF input to the CKP output??
Your problem is simple - you're missing a sensor and things aren't hooked up correctly.
If you're ECU is looking for a CKF input - then give it that.
Please don't apply this logic to other sensors - like the 2nd O2, for example. If you bought a header that only had one spot for an O2 sensor, do not use the output from the primary as the secondary input to the ECU, ya' follow?
Old Mar 1, 2005 | 09:37 AM
Default Re: p1300 and misfire codes for all 4 cylinders (EE_Chris)
i did this because i was geting a instant code for no crankshaft speed flucuation sensor
the code went away and has not come back since i did this i was just stating that i did that in case someone else did the same thing and got misfire codes from it
Old Mar 1, 2005 | 09:41 AM
EE_Chris's Avatar
But....you shouldn't have done it in the first place. Get a CKF sensor on there and see where that gets you with your misfiring problem.
FYI, the CKF plays a role in misfire detection - not having it there is more than likely the cause of your problems.
Old Mar 1, 2005 | 09:48 AM
there is no place to put one on my engine ,
can one be retro fited
Old Jan 8, 2012 | 04:09 PM
Darrin859's Avatar
What was The bad ground on i have the same problem my tach needle bounces when i go to get on it and the car hesitates a little just was wondering where the ground was so i can check mine out thanks i got the P1300 code on the obd2 at autozone..
Old Jan 8, 2012 | 04:32 PM
TheRealTegger's Avatar
The CKF sensor IS the misfire detection sensor.
I believe the number of teeth is different between CKP and CKF sensor wheels.
Old Jan 8, 2012 | 05:04 PM
DirtyDA9's Avatar
If you do not feel or notice the misfire the code may just be stored, after a condition occurs 3 or 4 times (depending on make) the ECU stores the code.
Edit: just realized you said the CEL comes on, nevermind the above then.
Old Jan 8, 2012 | 10:02 PM
Darrin859's Avatar
here is my link to my youtube video to what my tach gauge does..can anyone help figure out why? thanks ://www.youtube.com/user/darrin859
Old Jan 8, 2012 | 10:36 PM
el crapitan's Avatar
pretty sure tach signal is received through the ignitor in your distributor. what year is your car?
Old Jan 8, 2012 | 11:04 PM
DirtyDA9's Avatar
This.
Old Jan 9, 2012 | 12:06 AM
Darrin859's Avatar
my car is 1996...do you think it can be anything else? i changed the plugs,wires,cap and button.
Old Jan 9, 2012 | 12:10 AM
Darrin859's Avatar
your right but i get the P1300 code i floored it the other day on the interstate and it will only go 100 mph it acts like the rev limiter kicks in for some reason and the tach jumps...Any body have any idea?
Old Jan 9, 2012 | 12:43 AM
DirtyDA9's Avatar
Still the ignitor. Buy a new one, but buy one without the heat sink, it will be much cheaper, just swap the heat sink from the bad one.
Mr. Bojangles
Apr 26, 2013 07:47 PM
got-vtec?
Jul 23, 2011 02:26 PM
CleanLikeJdm
May 23, 2005 08:03 AM
BAZ
Apr 23, 2004 12:15 PM
TwoPointZero
Mar 27, 2004 07:23 AM
