VTEC kick point
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">it changes depending on manifold pressure ect. the minimum is 4800rpm max i believe is 5200
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by variable »</TD></TR><TR><TD CLASS="quote">Watch your tach and listen
I can easily hear it on my z6
And if you're too numb in the head to figure it out, take off your intake tubing and your axleback exhaust section and then the entire town will be able to hear when VTEC engages.
</TD></TR></TABLE>And if you're too numb in the head to figure it out, take off your intake tubing and your axleback exhaust section and then the entire town will be able to hear when VTEC engages.
That's what I was going to say earlier -
My Z6 with panel filter and no resonator = noticable VTEC X-over
Newer Y8's = not so noticeable
You could always wire up an LED to the VTEC signal wire - nice visual indication that it's working.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 »</TD></TR><TR><TD CLASS="quote">Mine does around 5600</TD></TR></TABLE>
did you mess with the engagement point? otherwise i say that your stock tach is hella off
provided that the car is up to temp, the oil pressure is good it should kick in at around 4500 + or - a small amount. Honestly the Vtec (on a SOHC) is difficult to distinguish from a car entering its peak rpms and pulling hard. This is due to the fact that all it is doing is effecting your intake valves vs. on a DOHC that changes both the intake and exhaust valves.
did you mess with the engagement point? otherwise i say that your stock tach is hella off</TD></TR></TABLE>
It is right around that somewhere when I barely hear it, lol. And no, never messed with it. Actually might be 5400, can't remember if it was before or after 5500, lol. I'll research it tomorrow.
Red D Dragon
May 31, 2005 09:56 AM
