b16 shift linkage ??????
Old Mar 1, 2005 | 07:17 AM
jdmap1's Avatar
Default b16 shift linkage ??????
I did some searching before posting and found nothing. Does the JDM EF B16 shift linkage fit directly (without modification) to a USDM EF in combination with a B-series motor???????? Please help
Modified by jdmap1 at 5:31 AM 3/2/2005
Old Mar 1, 2005 | 07:48 AM
Magick211's Avatar
Default Re: b16 shift linkage ?????? (jdmap1)
Yes it will work
Old Mar 1, 2005 | 08:00 AM
ricodemus's Avatar
with the hasport mounts, the shift linkage that came with the swap fit fine.
Old Mar 2, 2005 | 04:34 AM
jdmap1's Avatar
this dude is saying that "compare a stock B16A EF chassis and a US D-Series one... you'll see that the Jap motor mounts are WAY forward to clear the ALB system. All the aftermarket companies try to tuck the inake manifold as close to the firewall as possible for better axle geometry." Is that true? he is saying that the JDM EF B shift linkage needs modification to fit B swap in a USDM EF
Old Mar 2, 2005 | 04:36 AM
jdmap1's Avatar
Default Re: b16 shift linkage ?????? (ricodemus)
no stock shift linkage, not aftermarket ones.
Old Mar 2, 2005 | 04:51 AM
Magick211's Avatar
well he is right most mount kits do place the motor a lil closter to the firewall.
Old Mar 3, 2005 | 04:38 AM
ricodemus's Avatar
Default Re: b16 shift linkage ?????? (Magick211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">well he is right most mount kits do place the motor a lil closter to the firewall.</TD></TR></TABLE>
and depending on how they do it, it could possible mess up the axles I guess. I get some binding on my DSS axles, but I think its the axles more than the mounts since the stock axles were fine. Plus, suspension also plays a role in the axle geometry.
Not all mount kits are the same as far as how the place the motor so the general statement may not be true across the board. Like I said, the linkage I got with my swap wasn't cut or anything and it fit right in. We were surprised because I had always read that the linkage needed to modified, but this one seemed 100% stock and fit. I'm just assuming that it was a SiR linkage.
Old Mar 9, 2005 | 08:07 PM
jdmap1's Avatar
like wise, this linkage came out of a JDM crx. 100% stock. Well I sold it anyway so, whatever.
Old Mar 9, 2005 | 08:15 PM
EL Vap133's Avatar
Works with both Place Racing and Hasport mounts, and I know from experience.
moskaEF9
Sep 26, 2009 08:19 AM
bLuBoOrEx89_RAZORS_
Dec 31, 2007 12:32 AM
rcdohc
Jun 15, 2007 11:10 AM
RuthlessEF-9
Nov 25, 2005 06:24 PM
Jonnyr4c
Jul 4, 2005 02:34 PM
