93 integra axles
hey im using 93 integra axles for axles in my crx now some people said i might have to change the otter shaft. now i put them in and they slid right in and fit perfectly or do i still have to change them do to torque problems or something??? thanks
You will be fine, you need to remove the dust shields from the hubs and, there is a lil piece you pop off on the outer parts of the axles not sure whats its called though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 »</TD></TR><TR><TD CLASS="quote">You will be fine, you need to remove the dust shields from the hubs and, there is a lil piece you pop off on the outer parts of the axles not sure whats its called though</TD></TR></TABLE>
Isnt that the ABS ring that you have to pop off?
