2000 D16Y8 into 1999 Civic DX
I never had the cruise control on the DX. What are the components for the cruise control system. I am getting multiple codes such as general misfires and Idle Control System malfunction. On the EX engine there is a port that connects to the cruise control diaghram. Any help would be great.
Thanks
Diabl0451
Thanks
Diabl0451
Plug the cruise control port on the intake manifold to eliminate that source as a vacuum leak.
Are you wanting cruise control to eliminate "multiple codes such as general misfires and Idle Control System malfunction" or are you actually wanting cruise control? I've not heard of removing cruise control to be a problem on cars equipped with it - so not having it on yours should also not pose a problem.
What harness did you use? Did you re-wire/add wires anywhere?
MrRabbit87
Dec 10, 2008 09:38 AM
