skunk2 stage 2 cams
Old Feb 28, 2005 | 10:24 PM
JFG Kevin's Avatar
Default skunk2 stage 2 cams
I want to put in these cams in with a stock bottom and compression rate on a gsr.It's in a fully built head no port and polish but plan to tune with hondata. Am i going to make a good amount of power or i should just hold off and built bottom too?
Old Mar 1, 2005 | 07:34 AM
one slow coupe's Avatar
Default Re: skunk2 stage 2 cams (aznstyler119)
to run skunk stage 2s efectively you need 12:1+ compression to run those.
You will make power, but not as much as if you increased your CR
Save you money and get ITR pistons
Old Mar 1, 2005 | 08:42 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: skunk2 stage 2 cams (Honda_b16a2)
It's actually 11:1+ compression that's recommended for those cams to work best but they will make power in less compression. Your top and bottom end are separate so for now you could install the cams and use a thinner head gasket to help bump the compression a little. Then at a later time when money allows, you can build the bottom end and gain some more compression using JDM ITR pistons or something and extract more power from those cams.
Old Mar 2, 2005 | 09:37 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: skunk2 stage 2 cams (00Red_SiR)
I ran these in a stock compression b16a, ported head, portflow springs and retainers, sk2 intake manifold and 65 mm tb. they pulled hard from 4k-10k. you will be fine with these in your gsr, just be sure to upgrade your head, and raise your vtec xover. It wouldnt hurt to get a set of jdm itr pistons and new rings while you have everything apart. Good luck with your setup
Old Mar 2, 2005 | 10:16 AM
99-DC2's Avatar
These cams, properly tuned, rips especially at top end. I ran these on my stock GSR motor and got a little bit more power than people that ran Skunk2 Stg. 1 cams on average. If you increase your compression to 11:1 or over then you will truly experience how these cams sing.
Old Mar 2, 2005 | 10:53 PM
JFG Kevin's Avatar
Default Re: skunk2 stage 2 cams (DC2-99)
kewl..thx for the feed backs....i think imma just going to order some valves and hondata now...any thin gaskets recommecnd to get? for now?
Old Mar 3, 2005 | 05:05 AM
revvin9k's Avatar
See my sig.
Old Mar 13, 2005 | 02:40 AM
JFG Kevin's Avatar
Default Re: skunk2 stage 2 cams (S(J)O(D)L(M))
Arite....need some advise again to see if i should order it....Imma go order hondata s100, going to buy a oem head gastet... and put in the valvetrain with the stage 2...do you think i'll be makin some power....or it's not worth the time...and should save up...
Old Mar 13, 2005 | 09:48 PM
JFG Kevin's Avatar
bump...is itr necessary for me to get new valves...if i'm planning to get ctr pistons?
Old Mar 14, 2005 | 07:32 AM
00Red_SiR's Avatar
All Motor Mentor
no, stock size valves are fine.
Old Mar 14, 2005 | 09:43 AM
dwnthehatch's Avatar
I have cometic high compression head gasket for sale. PM me if you are interested.
Old Mar 14, 2005 | 03:24 PM
JFG Kevin's Avatar
well..not size...but do you think the stock valves will handle the compression and the rpm rate...i'll be up at?OEM honda
Old Mar 14, 2005 | 04:56 PM
sheepey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 &raquo;</TD></TR><TR><TD CLASS="quote">well..not size...but do you think the stock valves will handle the compression and the rpm rate...i'll be up at?OEM honda</TD></TR></TABLE>
yes
Old Mar 14, 2005 | 07:52 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: skunk2 stage 2 cams (sheepey)
If you don't plan on pulling your block apart, pick up a Mugen or Spoon headgasket to up the compression.
Old Mar 14, 2005 | 09:16 PM
HBK GABE's Avatar
Default Re: skunk2 stage 2 cams (LSVTEC 91 Civic)
I say bump ur compression and hold off on the cams.
Old Mar 15, 2005 | 04:47 PM
JFG Kevin's Avatar
Default Re: skunk2 stage 2 cams (626CivicSi)
ctr pistons first??i heard it's over camin the motor...which one should i do first...head or block??
Old Mar 15, 2005 | 06:59 PM
00Red_SiR's Avatar
All Motor Mentor
If you decided to do the block first I'd go with the JDM type R pistons instead of the CTR's. If you want to increase your compression over the 11:1 you'll have just go with a thinner head gasket, flat faced valves and/or plane a little of the head.
The bottom line is that you can run those cams now on your engine using a few tips listed above, to increase your compression without touching the block and still make good power.
Old Mar 15, 2005 | 08:28 PM
JFG Kevin's Avatar
Why not ctr pistons? thought more compression more better for those cams..
Old Mar 16, 2005 | 06:11 PM
00Red_SiR's Avatar
All Motor Mentor
More compression is good but it'll also require a lot more extensive tuning to get it to run properly at about 12.6:1 with CTR pistons in it. The fact is that Skunk says you only need about 11:1 to be in the ideal compression range for the cams to work well. It makes sense to build the engine so it's easily tunable and can be easily run on pump gas without problems.
Old Mar 16, 2005 | 06:13 PM
rusted_eyes's Avatar
I've got some for sale if you want!!!
Old Mar 16, 2005 | 10:22 PM
JFG Kevin's Avatar
o ic....thx for the info.....i'll keep you guys updated with teh project...if anyone else want to put down opinion...plz do...
Old Mar 23, 2005 | 12:13 AM
JFG Kevin's Avatar
Arite...I'm havin a bit3 of trouble pickin pistons...should i go for p30 or ctr??..or should i go with some other piston...I'm open to recommendations....remember..it's goin on stage 2 cams....what are most poeple running with these cams..
Old Mar 23, 2005 | 05:03 PM
00Red_SiR's Avatar
All Motor Mentor
P30's would be a nice choice and give you about 11.7:1 compression. If not those I'd go with the JDM ITR (p73-00) pistons for about 11.4:1.
Old Mar 23, 2005 | 05:50 PM
2k.civic.si's Avatar
ctr's in a gsr motor will yeild 12.45:1....then you can run a thicker headgasket from cometic the .040 will lower it .5 (or the .036 for little more compression) and give you just about 12.0:1 with increased valve clearance....the key here being the increased valve clearance....when i called skunk2 and asked them about running skunk2 stage2's in my poor man r setup they said i was cutting it close on the intake valve with clearance because of the 12.3mm lift....
ctr pistons + thicker headgasket will give you great compression with increased piston to valve clearance....perfect for skunk2 stage2's
Old Mar 23, 2005 | 06:19 PM
JFG Kevin's Avatar
Default Re: skunk2 stage 2 cams (2k.civic.si)
i'm planning to just get OEM head gasket...do you think that's thick enough?
