spun bearing...what do you replace?
i think my friend is on the verge of spinning a bearing. he wants to replace all the bearing, main and rod bearings, is there anything else that he needs to replace.
if the crank needs to be micropolished, he will get that done.
i was thinking he will need:
head gasket
maybe:
new rings
what do ya'll suggest for him?
thanks
head gasket
maybe:
new rings
thanks
While you're in there, go ahead and do the front and rear main seals as well as the oil pump. The water pump is also a suggestion, as is the timing belt, but they're also much more accessable.
well, we really don't know whats going on with his motor, we will no more wednesday.
i was thinking oil pump also.
it could be the oil pump thats going out and not even a bearing. we need to drop the oil pan.
boostedeghatch
15
Mar 2, 2005 12:55 PM
