H23 ecu's which one to go with
Old Feb 28, 2005 | 07:53 PM
chitown2769's Avatar
Default H23 ecu's which one to go with
I have a mildly built h23 in a 94 prelude, but it has a auto tranny right now.(I know, I know, I need a 5 speed). I have bored the block 20 over, je pistons, pauter rods, port polished head, and for a couple of months, stock cams( ran out of money) and all of the bolt ons from cam gears to msd igniton, cold air, ect. NOW to my question, for the time being is there another ecu I can run, possibly one for a manual tranny. I have heard that the fuel and air curves are a little greater on the 5 speed car, but will this cause a problem with throwing codes, if there is any other ecu that I could use PLEASE let me know.
Thank You
Old Feb 28, 2005 | 10:04 PM
SUB-0 H23's Avatar
Default Re: H23 ecu's which one to go with (chitown2769)
^^^ stick w/ what you have until you get some sort of engine management system...
Old Feb 28, 2005 | 10:56 PM
PirateMcFred's Avatar
I hope that your block holds up with those forged pistons. There have been many issues with the FRM cylinders and forged pistons.
Pirate
Old Mar 1, 2005 | 05:00 AM
kulrevon's Avatar
Default Re: H23 ecu's which one to go with (PirateMcFred)
the h23 had FRM cylinders too?
Old Mar 1, 2005 | 08:46 AM
hOndafienD 04's Avatar
Default Re: H23 ecu's which one to go with (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">the h23 had FRM cylinders too?</TD></TR></TABLE>
yes, h22 and h23 bare blocks are identical.
Old Mar 1, 2005 | 11:19 AM
LudeyKrus's Avatar
I doubt your setup from what you said, but there aren't really any other options for the P14, IIRC.
Old Mar 1, 2005 | 11:22 AM
SKDRCR's Avatar
Default Re: (LudeyKrus)
I believe Anthony (Precisionh23a) was running a p74 or a p75 ecu with his h23.
I believe you can use either of those with a hondata system.
Old Mar 1, 2005 | 12:17 PM
Default Re: (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">I believe Anthony (Precisionh23a) was running a p74 or a p75 ecu with his h23.
I believe you can use either of those with a hondata system.</TD></TR></TABLE>
i'll be running a p75 tuned shortly.
Old Mar 1, 2005 | 12:40 PM
GaRn's Avatar
Default Re: (hOndafienD 04)
you can run a P75, P05, or P06...
with the you are gonna have to mod it to keep the CEL from coming on b/c of the o2 heater or some bs..
socket the ECU and go with Uberdata...
research.
Old Mar 1, 2005 | 07:45 PM
Whar do you mean you doubt my set up? I can send pics and copys of invoices if thats what needs to be done. I just asked a simple question, but thanks for NOT helping.
Old Mar 1, 2005 | 08:04 PM
PrecisionH23a's Avatar
Yep, I ran the p75 when I ran hondata on my car. I now run AEM but that's a different story. I do a lot of h23 turbo builds and on every one that runs hondata I go with the p74/75 ecu.
Old Mar 2, 2005 | 11:57 AM
boomslang's Avatar
Since you are using an auto tranny, you cannot use a 5-speed ecu. Your current auto ecu works with a transmission control module (tcm) in order to properly operate the auto tranny.
You could switch to a P74/P75 auto ecu. However, I believe there are a few differences for the auto tranny specific pinouts.
If I remember tonight, I can post the differences.
Projectludatic
Oct 7, 2010 10:38 PM
mightymaxgst
Jan 20, 2009 08:31 PM
92LClude
Aug 9, 2006 09:06 PM
crazykid
Jul 25, 2006 04:55 AM
roycivic92
Jan 28, 2006 09:21 PM
