what are the best cams skunk2 stage 2??
Old Feb 28, 2005 | 07:30 PM
whytTypeR's Avatar
Default what are the best cams skunk2 stage 2??
seeing what gives out the horsepower.have a stock itr with forum racing pulleys act clutch 8.8lbs act flywheel.
Old Feb 28, 2005 | 07:55 PM
Chris F's Avatar
Default Re: what are the best cams skunk2 stage 2?? (whytTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whytTypeR &raquo;</TD></TR><TR><TD CLASS="quote">seeing what gives out the horsepower.have a stock itr with forum racing pulleys act clutch 8.8lbs act flywheel.</TD></TR></TABLE>
The mods you listed will NOT impact your cams decision.
What intake, header and exhaust are you running? Stock ECU still? Are you planning on getting cam gears, and/or dyno tuning or just bolting these in?
Old Feb 28, 2005 | 07:58 PM
Stein's Avatar
Default Re: what are the best cams skunk2 stage 2?? (Chris F)
Sounds like you don't have an intake, header or exhaust. Get quality parts of those first, then consider what yours goals are. Eirther build the block or go with a stock block and build the head.
Old Feb 28, 2005 | 08:04 PM
Kendall's Avatar
Perhaps include a budget as well, certain cams are hellishly more expensive than others.
Old Mar 2, 2005 | 09:03 PM
DeMeNtEdCtR's Avatar
Man, Tha best cams to get if you have tha money would be TODA Cams. If you want a stock valve train then get tha spec A cams. If you want tha Spec B or C cams you have to get Toda's valve springs and some retainers as well as there Cam gears too :thumbup. Everyone is going to say get skunk2 cams. There coo if you on a budget. If not get Toda. If you get Toda cams then it would be a good idea to get fuel managment too. I suggest Apex's power FC.
Old Mar 2, 2005 | 09:09 PM
white rocket's Avatar
Default Re: what are the best cams skunk2 stage 2?? (Stein)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stein &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you don't have an intake, header or exhaust. Get quality parts of those first, then consider what yours goals are. Eirther build the block or go with a stock block and build the head.</TD></TR></TABLE>
Boo-yaa
marshall12395
Nov 29, 2012 05:27 AM
BlackRocket
18
Nov 9, 2004 05:19 PM
Eric R
Dec 24, 2003 09:07 AM
b18cInside
Dec 19, 2002 05:41 AM
the big ragu
Jul 5, 2002 11:55 AM
