Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
FS: 2 sets of Ground Control AD shocks
Old Feb 28, 2005 | 07:07 PM
Jaker's Avatar
Default FS: 2 sets of Ground Control AD shocks
I have decided that the double adjustable ADs are too much for my little brain. I just picked up a 2nd set of them a little over a month ago, and now I'm selling both.
These are both compression and rebound adjustable aluminum bodied full coilover shocks. They are rebuildable by the end user, should you feel adventurous. Ground Control will also rebuild them for you for $50 per shock. The 1st set was purchased early last year, used, from another Honda-Tech member, whose name escapes me now. The 2nd set was purchased just this past month from Sam Lockwood (Honda-Tech username Raceworks).
Set one was originally configured for DC Integra using front spring rates from about 450-600 lbs, and rear rates of 650 to 850 lbs.
Set two was originally configured for EG Civic using front spring rates from about 500-650 lbs, and rear rates from 650 to 1,000 lbs.
I have bottom mounts for the rear shocks to fit ITR/88 Civic-CRX rear lower control arms mounted on set 2 at this time. Set one has DC/EG/EF USDM standard style fork mounts on it. I'm told by Sam Lockwood that the fork style mounts will also fit on EKs with the addition of a couple of shims to make up the difference in the bushing width.
I also have an extra set of shock bodies and an extra set of rear lower fork style mounts.
Both sets of shocks need to be rebuilt. I'm looking to get $850 shipped per set. They do not come with any springs. First come first served on the extra parts (mounts, shock bodies). I have some extra springs that I could add to the mix if the right buyer comes along.
Jaker
Nov 6, 2012 01:24 PM
DCshoecompany
Nov 18, 2007 12:17 PM
abstracthomie
Honda S2000
Sep 10, 2007 10:00 PM
Crank
Northern California (Sales)
Dec 29, 2006 02:11 PM
Jaker
Mar 2, 2005 08:33 PM
