ls motor in a 90 si help
Old Feb 28, 2005 | 04:53 PM
drowzysleeper's Avatar
Default ls motor in a 90 si help
a friend of mine got a free complete 1991 integra ls. he wants to swap the motor into his 90 si what will he need to complete the swap, instructions would be nice. thank you
Old Feb 28, 2005 | 04:59 PM
dr_latino999's Avatar
Default Re: ls motor in a 90 si help (drowzysleeper)
Did you search? And the answer to that question is no you didn't.
Keywords To Search For: Swap, B-Series, G.E.D., Basic English, Common Sense, Hasport
Modified by dr_latino999 at 9:23 PM 2/28/2005
Old Feb 28, 2005 | 05:00 PM
eda6's Avatar
your friend needs to search for instructions to complete the swap.
he needs mounts, linkage, ecu (he should search to see if i forgot something). car is already mpfi so vtec wiring must be added.
Old Feb 28, 2005 | 05:06 PM
kulangot's Avatar
Default Re: ls motor in a 90 si help (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">your friend needs to search for instructions to complete the swap.
he needs mounts, linkage, ecu (he should search to see if i forgot something). car is already mpfi so vtec wiring must be added.</TD></TR></TABLE>
he said its a ls, so you dont have to wire vtec...
Old Feb 28, 2005 | 05:13 PM
eda6's Avatar
Default Re: ls motor in a 90 si help (sirq2u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirq2u &raquo;</TD></TR><TR><TD CLASS="quote">
he said its a ls, so you dont have to wire vtec...</TD></TR></TABLE>
reading&gt;me
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: ls motor in a 90 si help (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Did you search? And the answer to that question is no you didn't.
Keywords To Search ForSwap, B-Series, G.E.D., Basic English, Common Sense, Hasport</TD></TR></TABLE>
BWAHAHAHAHAHAH
sigging
Old Feb 28, 2005 | 05:18 PM
CRX_1.8T's Avatar
Your friend will need to:
* shorten the 90-93 shift linkage by 2 3/8 inches.
* get some decent mounts, might as well get Hasport ones.
* dent the frame rail in about half an inch to have clearance for the alternator.
* dent the area near the rear mount (on the rear crossmember). Hasport's instructions show what to do.
* he might as well change the timing belt, water pump, oil pump, and all of the seals while the engine is out. That would be gay if one of these failed on him.
* you'll need a 90-91 Integra throttle cable, and keep your Civic speedometer cable drive.
* 90-93 axles
There is more, but that is all that I can think of at the top of my head. There are hella people on here that can help you guys with all of the actual wiring, I suck at that so I can't help you sorry.
Good luck
1sikhatch
Sep 6, 2007 12:22 PM
EG2uNnEr209
Jul 22, 2006 09:59 PM
chuckieD
Oct 5, 2005 10:45 AM
HybriDNA
Sep 25, 2002 10:04 PM
