Best pistons for this application?
Old Feb 28, 2005 | 02:33 PM
greddy2die's Avatar
Default Best pistons for this application?
Whats up guys, I need your guys help on something.
Im selling my RX7:
http://www.rx7club.com/showthread.php?p=4084842
With the money im gonna get from it im buying my friends 4door teg and dropping in a motor he started building but never finished. The only things needed to complete the motor are pistons and rods.
My question is, what oem pistons and rods do you think would take the best advantage of the following mods.
Skunk2 Stg2 cams
Skunk2 Valves
Skunk2 Retainers
Skunk2 springs
AEM Cam Gears
GSR crank
Thanks for the help
also, what head gasket would you guys recommend? OEM or something else
Old Feb 28, 2005 | 02:35 PM
Almtrhb's Avatar
Default Re: Best pistons for this application? (greddy2die)
What block? Daily driver im assuming
Old Feb 28, 2005 | 02:36 PM
greddy2die's Avatar
Default Re: Best pistons for this application? (Almtrhb)
gsr block.... yeah it will be my daily i guess for a little while
Old Feb 28, 2005 | 02:48 PM
NJIN BUILDR's Avatar
If you want an oem then probably the jdm type r (p73-00).That will get you 11.7 to 1.The usdm type r (p73-ao) would also work and will give you a touch over 11.1:1.
Glenn
Old Feb 28, 2005 | 07:07 PM
greddy2die's Avatar
Default Re: Best pistons for this application? (NJIN BUILDR)
hmmmm jdm type r pistons sounds like it would be pretty good for me to get then
Old Mar 1, 2005 | 06:49 PM
v-6 hatch's Avatar
stick with oem eitehr the j-spec itr's or if u wnat to get real busy try some ctr's
Beto_619
May 23, 2016 07:29 PM
Beto_619
May 17, 2016 07:37 PM
kainoner
18
Mar 31, 2009 09:46 PM
BMO98GSR
May 1, 2008 09:01 PM
Thrashin
Nov 16, 2003 02:24 PM
