Do I have Cable or Hydro Tranny?
Old Feb 28, 2005 | 12:10 PM
NathanMorris's Avatar
Default ...
zurg's Avatar
Default Re: Do I have Cable or Hydro Tranny? (92Lx)
hydro tranny
Old Feb 28, 2005 | 12:11 PM
skip.two's Avatar
its a hydro.
Civic's 92+ are hydro
Integra's 94+ are hydro
Old Feb 28, 2005 | 12:13 PM
Jimmy's Avatar
Global Moderator
I'm pretty sure that the EF civics and the DA (90-93 model integras) have cable clutches...
Del Sol SiR's Avatar
it is possible that you have a cable tranny though... I've seen swaps where they got rid of the hydro for cable... got a pic ?
skip.two's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure that the EF civics and the DA (90-93 model integras) have cable clutches...</TD></TR></TABLE>
yes, they do. what are you talking about Jimmy? haha
that would suck if they put in a cable tranny.
Old Feb 28, 2005 | 12:41 PM
T-25ej6's Avatar
Hydroponics smoke good
Old Feb 28, 2005 | 02:54 PM
Tokyo_X-treme_Racer's Avatar
New User
What is the difference between a hydro and cable trannies? Can anyone explain?
Old Feb 28, 2005 | 03:30 PM
Combustion Contraption's Avatar
On a cable trannie the clutch is operated by a cable controlled by the clutch pedal, on the hydro, its operated by a fluid filled line, hence the 'hydro' or 'hydraulic' term.
Old Feb 28, 2005 | 03:33 PM
pane93civhb's Avatar
Default Re: (LsVtec92Hatch)
appearance difference would be a big metal bar on the front side or the tranny.. with a loop looking thing at the end.. and on a hydro tranny it will have a square whole with a boot on it or a metal spoon looking like thing sticking out of it.. and it has 2 holes to mount the master cylinder that pokes the lil spoon looking thing.. in lay mans terms for all yall cats dat dont live under the hood..lol.. good luck though that motor runs good in hatches.
Old Feb 28, 2005 | 03:38 PM
B16aDasher's Avatar
Default Re: (pane93civhb)
if it is a 95 ls engine i guessing it hydro. You would have it check it tho. Or get someone to check it for you.
Old Feb 28, 2005 | 03:41 PM
If its a 95 its a hydro for sure.
lilo_goki
Apr 20, 2007 11:25 PM
91' LS-VTEC
Apr 19, 2006 12:48 AM
spazz0nater
11
Mar 25, 2006 05:07 PM
1TwistedEG
Mar 18, 2005 07:28 AM
hyperazn108
Apr 14, 2004 09:16 PM
