Main relay Problem??
Old Feb 28, 2005 | 12:05 PM
Pandahatch93's Avatar
Default Main relay Problem??
My fuel pump isn't turning on when key is on the on position, but i hear a buzz noise coming from my main relay. What does that mean?
Modified by Pandahatch93 at 1:46 PM 2/28/2005
Old Feb 28, 2005 | 12:42 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Main relay Problem?? (Pandahatch93)
usually when it is cold thats when the main relay locks up. it should be replaced.
Old Feb 28, 2005 | 12:47 PM
Default Re: Main relay Problem?? (boostedcivicsir)
Thanks anything else?
Old Mar 1, 2005 | 04:52 AM
EE_Chris's Avatar
Well, if you have an older Civic, like a 5th gen, chances are that your Main Relay is going bad. If you have a soldering iron handy, remove the relay and touch up the solder joints.
If this doesn't eliminate the problem, your Main Relay may need to be replaced.
turbocivic1984
Jun 29, 2008 09:59 AM
JDMdamian95
May 1, 2006 09:45 PM
90civicturboed
Jul 29, 2005 08:47 PM
SOHCwarrior
Jul 4, 2005 05:40 PM
