Integra VS ZC ecu which one to use
Old Feb 28, 2005 | 09:33 AM
crix351c's Avatar
Default Integra VS ZC ecu which one to use
Help....I have a 88 Rex with DOHC ZC I have an integra ecu and the ZC ecu that came with the motor..>Which ecu should i use....and does anyone know a shop where i can get the rev limiter change on the ZC ecu....Can you use an automatic ecu in a 5 speed car...Thanks guys
boof
Old Feb 28, 2005 | 11:19 AM
crxnj's Avatar
Default Re: Integra VS ZC ecu which one to use (crix351c)
Use the zc ecu..Because afterall its made for the motor..
And there are shitloads of integra ecu's,Maybe you should specify which one you have..Most integra ecu's have to high of a redline and they will make the motor run pig rich..
Old Feb 28, 2005 | 11:53 AM
HondaKPX's Avatar
Default Re: Integra VS ZC ecu which one to use (Mr.speaker)
i would get yourself a 90-91 PM6 and run Turbo edit on it. i got a pg7 for mine and it runs rich as ****. and im going to be making myself a turbo edit one soon anyways so it was kinda a waste of money
beatthisspeed69
May 16, 2006 09:54 AM
88 turbo crx
Feb 7, 2005 10:18 PM
South Bay Surfer
Feb 29, 2004 12:10 PM
stock_cx
Dec 31, 2003 10:26 AM
nihkon
Aug 2, 2002 11:11 AM
