HX rims wont rotate with integra brakes...need help.
Old Feb 28, 2005 | 08:45 AM
menappi's Avatar
Default HX rims wont rotate with integra brakes...need help.
i posted this in the EF forum..but i thought maybe someone in here has had HX rims on their teg....
k so i put hx rims on my hatch..but i have DA front brakes. the rims r fine on the rear but the front..they wont turn. they go on fine but when i bolt them down they wont turn. then when i try to pull them off it shard to get htem off..like they are stuck on something. what should i do. i had my stock crx si wheels on there no prob..and i think they are both 14"...could i use washers or something?
Old Feb 28, 2005 | 09:02 AM
DragnDriftphil's Avatar
Default Re: HX rims wont rotate with integra brakes...need help. (menappi)
Dude your wheels are hitting your brake caliper, they're not gonna work. You need at least 14 in wheels for the teg brakes.
Old Feb 28, 2005 | 09:13 AM
Spoodge's Avatar
From: Slut City aka San Diego, Ca, United State Of King
the vx 13's will not fit.. the hx 14's will rub the brake.. you need to get 5 mm wheel spacers..
Old Feb 28, 2005 | 10:36 AM
StatGSR's Avatar
Default Re: (SpoodgeDc2)
yea u need spacers to clear...
Old Feb 28, 2005 | 11:27 PM
menappi's Avatar
wth is a spacer. i posted the same thing in the EF forum and i got a link to grindin down the caliper a little.
Old Feb 28, 2005 | 11:33 PM
Rtistik.'s Avatar
Default Re: (menappi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menappi &raquo;</TD></TR><TR><TD CLASS="quote">wth is a spacer. i posted the same thing in the EF forum and i got a link to grindin down the caliper a little. </TD></TR></TABLE>
grinding the caliper works too
Old Feb 28, 2005 | 11:35 PM
M-EJ1's Avatar
Default Re: (rtistik)
If you've got an air grinder and a little bit of patience you can take the material off the caliper, if not then just get some spacers.
Old Mar 1, 2005 | 06:51 AM
92blackg2's Avatar
Default Re: (M-EJ1)
wouldn't spacers be economically better though, I mean I don't know anything about grinding the caliper and what it does but my friend used spacers for his car and diddn't pay much for it
Old Mar 1, 2005 | 09:37 AM
menappi's Avatar
WHAT IS A Spacer?! any pics? where can i get them? sorry ive never had to deal with this.
Old Mar 1, 2005 | 09:40 AM
iH8RICERZ's Avatar
I did a quick froogle search.....
http://www.pure-motorsport.com...PA=10
check it
99_red_si
Aug 4, 2006 06:49 PM
jsull.
May 15, 2005 12:11 AM
menappi
Mar 1, 2005 04:02 AM
airon
May 10, 2002 09:37 PM
Black R
Apr 3, 2002 02:04 PM
