hx wheels with integra brakes help!
Old Feb 28, 2005 | 08:41 AM
menappi's Avatar
Default hx wheels with integra brakes help!
k so i put hx rims on my hatch..but i have DA front brakes. the rims r fine on the rear but the front..they wont turn. they go on fine but when i bolt them down they wont turn. then when i try to pull them off it shard to get htem off..like they are stuck on something. what should i do. i had my stock crx si wheels on there no prob..and i think they are both 14"...could i use washers or something?
Old Feb 28, 2005 | 01:36 PM
Wes V's Avatar
Default Re: hx wheels with integra brakes help! (menappi)
here is a link that may help
http://faq.ef-honda.com/index....ng=en
Wes
Old Feb 28, 2005 | 02:04 PM
thenick's Avatar
Default Re: hx wheels with integra brakes help! (Wes V)
or use spacers
Old Feb 28, 2005 | 11:26 PM
menappi's Avatar
hey thanks! whats a spacer..i read about that..but im not sure exactly..where do i get those. im thinkin ill just grind the caliper.
Old Mar 1, 2005 | 02:14 AM
SloA$$ DA's Avatar
Default Re: (menappi)
spacers or could washers work? ive wanted to put hx wheels on my da but i knew that the calipers are too big to clear with the hx's. so would washers on the stud work too ?
Old Mar 1, 2005 | 04:02 AM
Targa250R's Avatar
be professional
Default Re: (SloA$$ DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloA$$ DA &raquo;</TD></TR><TR><TD CLASS="quote">spacers or could washers work? ive wanted to put hx wheels on my da but i knew that the calipers are too big to clear with the hx's. so would washers on the stud work too ?</TD></TR></TABLE>
Don't use washers. The thickness wouldn't be as uniform as a spacer, and you could end up with a crooked wheel. Not to mention it would make the wheel lug-centric instead of hub-centric.
vtecdc2
Aug 17, 2006 06:44 PM
menappi
Mar 1, 2005 09:40 AM
Yak BallZ
18
Feb 10, 2005 05:13 PM
dirty_dan
Oct 30, 2004 11:20 PM
spoon23_JDizM AkA SpOoN20
Apr 1, 2004 05:27 PM
