My essay about B-series engines
Old Feb 28, 2005 | 04:52 AM
spcrxracer's Avatar
Default My essay about B-series engines
Modified by spcrxracer at 2:59 PM 3/2/2005
Old Feb 28, 2005 | 05:29 AM
CRX_Control's Avatar
Default Re: My essay about B-series engines (spcrxracer)
nothing about the b20's?
Old Feb 28, 2005 | 05:38 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: My essay about B-series engines (CRX_Control)
How about adding information about the B16B along side with the ITR, can't forget the CTR.
Nice essay, you get t3h A+.
Old Feb 28, 2005 | 07:53 AM
VashTheStampede's Avatar
No tears. Only dreams, now.
You forgot the NSX...
What is this class for? I can see someone who isn't into this kind of thing failing you....
Personally, if it were for an english class, I'd give you a C because you jumped around quite a bit. But that's just me...
Pretty good though...
Old Feb 28, 2005 | 09:08 AM
c1v1c89h4tch's Avatar
Default Re: (VashTheStampede)
nice essay, like how you compared things
Old Feb 28, 2005 | 09:14 AM
NikoZai's Avatar
Default Re: (c1v1c89h4tch)
if your teacher does know anything about the subject you'll get a B for calling an engine a motor. LOL If i was your teacher i would ask you if you know the difference between motor and engine
Replace "motor" with "powerplant" since i know you're trying not to be redundant by using engine over and over.
Old Feb 28, 2005 | 09:16 AM
daidilus's Avatar
you know that feels like i have read it before...about 3-4 years ago from a website.....
Old Feb 28, 2005 | 09:29 AM
evilricer's Avatar
Default Re: (daidilus)
wasnt the b16 in the civic from 99-00? i didnt know they put them in 1998 and 2001 models also.
Old Feb 28, 2005 | 09:37 AM
FalkenSiR's Avatar
Default Re: (evilricer)
Nice, but you went back and fourth witn engine and motor. B+ for the effort.
Old Feb 28, 2005 | 09:40 AM
.Noah Fecks's Avatar
Default Re: (fast88std)
the first b series vtec motor was in japan in the 80s fool
Old Feb 28, 2005 | 12:02 PM
gtarwiz's Avatar
Default Re: (Noah *****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noah ***** &raquo;</TD></TR><TR><TD CLASS="quote">the first b series vtec motor was in japan in the 80s fool</TD></TR></TABLE>
i think he was just going for the B-series engines that were introduced to the US, and we didint start getting them until the early 90's like he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spcrxracer &raquo;</TD></TR><TR><TD CLASS="quote">transplanted into most fourth- to sixth-generation (1990-2000) </TD></TR></TABLE>
fourth gen started in 88 not 90
if I was clueless about htis subject, and I had to grade a paper like this, I wouldn't give it to high of a grade. Most people, when it comes to cars or anyhting mechanical in papers, get automatically turned off by it. I think this stuff is interesting but most people dont. You were pretty good about not getting to technical with everything. Ill give a B for good effort
Old Mar 1, 2005 | 06:55 AM
spcrxracer's Avatar
Default Re: (eric.ws.anderson)
I had to write this for my freshman comp class. I had info about the JDM B16s and the B16B but my professor told me i needed to "narrow down my focus to just the US versions." I was pissed because i had to cut out so much info.
Old Mar 1, 2005 | 07:23 AM
slowpokesi's Avatar
Default Re: (spcrxracer)
for the record, Honda did not invent variable valve timing, it has been around in other engines before Honda started using the technology. I would say that Honda has had more sucess with variable valve timing than other companies.
Also i would try to find a diffrent word than "interchangeability" it just doesnt sound right.
Old Mar 1, 2005 | 03:42 PM
Qfactor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spcrxracer &raquo;</TD></TR><TR><TD CLASS="quote">The first of the VTEC B-engines was the B17A, making its appearance in the 1992-1993 Acura Integra GS-R. This rare engine was Honda’s first use of VTEC in the United States. This rare engine pumped out an impressive 160 horsepower.
Wrong the first Honda car to use vtec in the USA was the 1991 NSX. also your essay does not mention anything about engine displacement. motor(electric) engine (gas/diesel) unless your'e talking about a Hybrid Honda that has both.
Old Mar 1, 2005 | 03:52 PM
.Thomas's Avatar
Default Re: My essay about B-series engines (Qfactor)
make it longer, and you use the in every first word of like 5 paragraphs. chage it up a bit, what what class/grade are you in?
Old Mar 1, 2005 | 04:01 PM
KFBhonda's Avatar
u b wrong about sum ****
but u get en e for effort
Old Mar 2, 2005 | 04:29 AM
StorminMatt's Avatar
Default Re: (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">if your teacher does know anything about the subject you'll get a B for calling an engine a motor. LOL If i was your teacher i would ask you if you know the difference between motor and engine
Replace "motor" with "powerplant" since i know you're trying not to be redundant by using engine over and over.</TD></TR></TABLE>
An engine is a device that converts (some fraction of) heat energy into some form of useful work. A motor is a device that generates motion. It is therefore completely proper to refer to an internal combustion engine as a motor (since it does generate motion). An electric motor, on the other hand, is not an engine. It does not convert heat to work (it converts one form of work - electricity - to another). And thermoelectric and thermionic generators are engines, but not motors. They convert heat energy into useful work in the form of electricity, but don't generate motion. In fact, these devices are completely devoid of moving parts!
Also, the B18A/B18B were NOT the first B-series motors. Just the first B-series motors in the US. The B16A came first.
Old Mar 2, 2005 | 04:57 AM
davens's Avatar
Why didn't I get to write crap like this when i was in school...what school was this?
Another stickler point:
"VTEC, Honda’s acclaimed invention, is what sets the B-series engines apart from other production engines. "
You make it sound like VTEC is exclusive to the B-series or Honda. But it came on the NSX(C-series?) and the D-series too.
There are several variable valve technolgies available from other manufacturers:
BMW VANOS - Varies intake and exhaust timing and lift by moving the fulcrum of the camshaft
Ford Variable Cam Timing - Varies valve timing by rotating the camshaft
GM Variable Valve Timing - Varies timing (phase) with hydraulic pressure
Honda i-VTEC - Adds cam phasing (timing) to traditional VTEC
Mazda S-VT - Varies timing by rotating the camshaft
Mitsubishi MIVEC - Varies valve timing and lift
Nissan VVL - Varies intake, duration, and lift by using two different sets of cam lobes
Porsche VarioCam - Varies intake timing by adjusting tension of a cam chain
Porsche VarioCam Plus - Varies intake timing by adjusting tension of a cam chain
Rover VVC - Varies timing and lift with an eccentric disc
Subaru AVCS - Varies timing (phase) with hydraulic pressure
Toyota VVT-i - Varies intake timing by advancing the cam chain
Toyota VVTL-i - Varies timing by advancing the cam chain and switching between two sets of cam lobes
Makes you wonder why VTEC is considered so special
Old Mar 2, 2005 | 06:14 AM
Qfactor's Avatar
Default Re: (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
I'll give you a C for this paragraph.
Old Mar 2, 2005 | 07:00 AM
PaImportTuner's Avatar
Default Re: (Qfactor)
i like toyotas VVTLI they use BMX and Nissan and bring forth a monster.
you gotta love them 1.8 GT-S motors producing more hp and tq then a b18c1.
Old Mar 2, 2005 | 04:16 PM
KFBhonda's Avatar
VTEC is considered special b/c Honda was the first to successfully implement variable valve lift & timing on a mass-production engine.
Feel free to correct me if I am wrong.
Old Mar 2, 2005 | 05:37 PM
EL Vap133's Avatar
Modified by spcrxracer at 2:59 PM 3/2/2005</TD></TR></TABLE>
Wow, what a nice essay.
chrisxmichael
24
Aug 31, 2011 10:02 AM
Scubster
123
Jul 28, 2006 11:19 PM
WhoisDan
Mar 20, 2006 02:55 PM
2camsaam
106
Mar 3, 2003 01:26 AM
MiraiZ
Nov 26, 2002 09:14 AM
