Possibility of a 6 speed???
Okay, is there any chance in hell of being able to come up with a six speed B-series transmission? This would be a nice way to keep the engine's cruising speed lower on a turbocharged car, and closer gear ratios wouldn't exactly hurt the acceleration...
Just an idea, it may not be possible...
what are the gear ratio's of the b20 trannie you would think that the gears on that beast would be taller than needed for you tuubo.
im guessing its not really an option seeing that APEXi decided to make an engine spin backwards and reverse mounted it, in order to hook up a 6 speed in their drag integra heres the link http://www.turbomagazine.com/archive...e09_answer.jsp
The quafie box is for NORMAL FWD engines, not Hondas.
Hint, see what APEXi did to get tranny to work!
B20 gear ratios are JUNK! Go LS is boost + low rpm cruisng is your wish.
bsmith100
27
Aug 16, 2010 03:00 PM
psychadelicfreedom
29
Jan 9, 2004 01:00 PM
Trey
Jan 23, 2002 05:58 PM
