dpfi to mpfi Distributor
hey all whats up...i was juss wonderin on how to wire my Dx Dizzy for MPFI....i dont feel like spendin another 150$ on a dizzy so yeah...any help would be appreiciated...and yes i did search
i dont think you can, the si dizzy has the CPS sensor on it,that's why you cant use the dx's.
unless theres a ghetto way of by-passing it,but i dont think there is.
i second that claim. that sensor is the difference between the td-01 dizzy and td-18. the plugs on the 2 are also very different. i think the td-01 is only a 4 pin plug, and the td-18 is a 7 pin.
nope DPFI dizzy wont work, you won't have a cylinder position sensor.
ebay
Then have Rywire take care of it for you
ebay
greg your gonna have to fork out the cash for the mpfi dizzy
there is a white 91 hf at dumpletins grab that one i took the plug off it if you get it ill help you wire it up
I have a 1990 crx DX in the middle of the dpfi to mpfi conversion, with a SI intake manifold, and 4 injectors, It does have the SI dizzy, but only 2 bolts line up, I know that there are 3.. is this how its supposed to be, or should all 3 line up just like to old one? I do not have the old d15b dizzy I bought the car without it..
Modified by dohdoh420 at 9:29 PM 3/7/2005
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp »</TD></TR><TR><TD CLASS="quote"> i think the td-01 is only a 4 pin plug, and the td-18 is a 7 pin. </TD></TR></TABLE>
no the DX (or LX for sedans
) is a 5 wire. 2 each for the 2 sensors and 1 for the electronic advance.
the EX or SI is the above + one more 2 wire sensor.
) is a 5 wire. 2 each for the 2 sensors and 1 for the electronic advance. the EX or SI is the above + one more 2 wire sensor.
92coupe
12
Nov 5, 2010 08:30 PM
JDMkid413
Jun 11, 2009 03:16 PM
classciv
Apr 2, 2006 03:30 PM
Agent Daimon
Dec 17, 2002 03:42 AM
