Can a Auto P13ECU run on a Manual Prelude Si
Old Feb 28, 2005 | 01:02 AM
OzWolfbane's Avatar
Default Can a Auto P13ECU run on a Manual Prelude Si
Hi,
I am doing a conversion Si --> VTEC , But all the guy has are Engines off AUTO cars with AUTO ECUs !!! Can they be installed on a Manual Prelude ?? The guy said u just dont use the Auto wires and it runs fine...is he just trying to sell it or is he right ??
ta
Old Feb 28, 2005 | 04:13 AM
Dougs96SI's Avatar
Default Re: Can a Auto P13ECU run on a Manual Prelude Si (OzWolfbane)
Hes just trying to sell. The ECU needs to be replaced with one that is programmed for a vtec manual lude, then it will work
Old Feb 28, 2005 | 05:45 AM
clemsoncb7's Avatar
Default Re: Can a Auto P13ECU run on a Manual Prelude Si (Dougs96SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">Hes just trying to sell. The ECU needs to be replaced with one that is programmed for a vtec manual lude, then it will work</TD></TR></TABLE>
Yup, he's a salesman. Oh yea, and if you're looking for a p13manual, I have one. Let me know
Old Feb 28, 2005 | 10:37 AM
prelittlelude's Avatar
arg... n00bies replying... ^^^
go to pgmfi.org, in the library under the hardware mods, you can convert an auto p13 to manual.
edit ah, i did it for you :
http://www.pgmfi.org/twiki/bin...anual
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgmfi.org library &raquo;</TD></TR><TR><TD CLASS="quote">
Author: Zoltan (user97.209.42.32.dsli.com)
Date: 09-08-03 00:35
Got it! All I had to do was remove rp11. Bam no CEL What was once automatic is no longer :D </TD></TR></TABLE>
Old Feb 28, 2005 | 01:35 PM
md23vtec's Avatar
Actually you <U>can</U> use an auto Obd1 p13 from an automatic ina manual and it will work and not give a CEL. I belive the fuel curve is slightly differnt but to answer your question it <U>will</U> run a manual.
Old Feb 28, 2005 | 06:43 PM
OzWolfbane's Avatar
thanks prelittle lude, but how do u do that ???
Fuel curve different I think its just bad news trying the auto ECU ... should just try to find a JDM Manual ECU
Clumsy818
Jan 29, 2013 07:28 PM
vietherbs
Sep 9, 2007 08:38 PM
ukvtec
Aug 20, 2004 08:19 PM
Tad
20
Jun 5, 2004 01:11 PM
5STAR3
Apr 28, 2004 11:32 AM
