17s changing to gsr blades,lowered not alot,look different????
Old Feb 27, 2005 | 11:51 PM
gsacuraintegra99's Avatar
Default 17s changing to gsr blades,lowered not alot,look different????
i have 17s right now and im lowered about 1.5 in front and if i get stock gsr blades,will there be a little gap in the wheels because the rims are smaller,and my car is not lowered that much,thanks
Old Feb 28, 2005 | 07:43 AM
TURBO DC2's Avatar
Default Re: 17s changing to gsr blades,lowered not alot,look different???? (gsacuraintegra99)
What size tires did you have on the 17s and what size tires do you have on the 15s. We need more info You can have 17s with 35 profile tires and 15s with 55 size tires and be around the same size in overall diameter.
Old Feb 28, 2005 | 10:14 AM
O3ASEVO's Avatar
Default Re: 17s changing to gsr blades,lowered not alot,look different???? (slammed_gsr)
yes it will look different and it will ride smoother aswell. Just lower it more on the 15's and itll look nice.
Old Feb 28, 2005 | 12:48 PM
TeaAddict's Avatar
if you used the recogmended size tires for your 17's (205-40-17) and the suggested tires for your 15 blades *i forget what these are* the wheel gap should be equal. you should be fine with a 1.5 inch drop.
Old Feb 28, 2005 | 04:12 PM
Default Re: 17s changing to gsr blades,lowered not alot,look different???? (TeaAddict)
aight thanks man
Old Mar 1, 2005 | 08:15 PM
MugenGSR2001's Avatar
195-55-15...I believe thats the recommended size...
smigga77
Nov 8, 2010 10:43 AM
Bakuryu06
Sep 10, 2010 04:59 AM
Lee_eg6si
Jul 25, 2008 02:44 PM
legends
Oct 2, 2005 02:09 PM
Wiseguy619
Oct 17, 2003 08:40 AM
