Complete Turbo Kit **Cheap***
Old Feb 27, 2005 | 09:10 PM
Endoe's Avatar
Default Complete Turbo Kit **Cheap***
Rev Hard Stage II Kit about about 70k or less....Still in my car and driving it to work everyday...
All Included:
GT30R Dual Ballbearing Turbo (No Shaft Play) Spools at 2000 RPM
RH Charge Pipe
RH DownPipe
RH Manifold
RH Front Mount Intercooler
Similar to this but not chrome...painted black
High Pressure T-Clamps
Vortec BOV
Turbo Smart 35MM Wastegate
450cc Injectors DSM w/Resistors
OBD1 LS ECU map for this setup
68mm STR Throttle Body
DH Ported LS manifold
Greddy Profec B Boost Controller (Got it from Robert)
Blitz Turbo Timer
Spearco Boost Gauge
Vacuum Lines (A lot of them)
Eagle Vacuum Manifold
Walbro High Pressure Fuel Pump
Clean Tapped LS Oil Pan (No Leaks)
3" Exhaust System Mandrel mainly for 4dr Teg but customize for others?
Has 2 O2 Bong for wideband
$3500 or Best Offer.... I think that is not bad at all... this will bolt onto a 94 and up LS and ready to run.... perfect for a LS 4dr or 2dr
LMK 559-999-3912 (WILL NOT PART)
Modified by Endoe at 8:56 PM 3/1/2005
Old Feb 27, 2005 | 09:45 PM
SHystrdyGSRtdy's Avatar
Default Re: Complete Turbo Kit **Cheap*** (Endoe)
if you'd like to part out... i'm interested in the fuel pump and maybe the vacuum manifold
Old Feb 28, 2005 | 08:09 AM
Endoe's Avatar
Default Re: Complete Turbo Kit **Cheap*** (SHystrdyGSRtdy)
Maybe..but for now im trying to sell the complete kit... so my car can be stock again....new price $3200... this is pretty much complete for turbo setup... has everything except tunning....but that is different on every car...
Old Feb 28, 2005 | 05:15 PM
PBzAllan's Avatar
how big is that intercooler?
Old Feb 28, 2005 | 08:09 PM
Endoe's Avatar
Default Re: (PBzAllan)
The regular size from Rev Hard...
Modified by Endoe at 8:54 PM 3/1/2005
Old Mar 1, 2005 | 05:36 AM
spooncivic1's Avatar
if you part it out, i'd like the turbo, manifold and downpipe
Old Mar 1, 2005 | 11:57 AM
Endoe's Avatar
got a offer but still pending...
TeenyTymer69er
Aug 11, 2010 10:00 PM
DaYZeD.1
Nov 11, 2008 12:02 AM
Shady Hills
Jul 13, 2003 09:16 AM
