interior light bulb #?
Old Feb 27, 2005 | 06:07 PM
MtnCRX's Avatar
Default interior light bulb #?
anyone know the number for the bulb on the ceiling that turns on when door opens or when u switch it on? the numbers like 3610 or 3910 or something along those lines...
Old Feb 27, 2005 | 06:25 PM
B2FiNiTY's Avatar
Default Re: interior light bulb #? (MtnCRX)
http://www.slyvania.com
Old Feb 27, 2005 | 06:26 PM
coot_er's Avatar
auto zone
courtesy light #3022
Old Feb 28, 2005 | 03:49 AM
SpecialEdxl's Avatar
hhmm......if i had know this when i liked the light haha
Old Feb 28, 2005 | 04:23 AM
GoFastTshirts.com's Avatar
Default Re: (SpecialEdxl)
does anyone have the problem of the courtesy light turning on while driving ? i have mine set to the middle position so the sight comes on with the doors open but when i hit the gas or hit a bump it moves slightly to the on position any fixes ?
Old Feb 28, 2005 | 08:29 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (RexOwner)
from the factory,there was a rubber boot on the switch,
Most likely yours is missing..It helps push the switch just a little further..
Try putting a rubber vacuum cap on it..
Old Feb 28, 2005 | 01:13 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexOwner &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have the problem of the courtesy light turning on while driving ? i have mine set to the middle position so the sight comes on with the doors open but when i hit the gas or hit a bump it moves slightly to the on position any fixes ?</TD></TR></TABLE>
actually, open up that sensor shown above in the pic. then clean off the contact with something hard to scrape off the corrosion and it will not occur anymore. thats all it is. corrosion on the sensor.
bigbookben
Aug 7, 2018 02:26 PM
therichisgood
Apr 1, 2014 02:27 PM
boostedr
Jul 15, 2009 11:56 PM
wishingiam
Mar 17, 2005 09:06 PM
EFSiR
Jun 1, 2003 03:12 PM
