What kind of grease Honda use?
hey everyone... I was changing my brakes today and I wanted to take out the caliper pins to see if they are ok and maybe lube it up. I was wondering if anyone know what kind of grease honda use for this? It is a brownish, very very thick grease.
Don't know exactly what Honda call theirs, but other garages use what's called "Copperslip", it's a thick goldish brown Copper based grease that's heat resistant and won't let components seize up I use it around anything that is prone to seize from heat or corrosion like brakes, exhaust, wheel studs etc.
I actually went to kragen today and saw their assortments of grease. Does anyone know whats the difference, or which is better, the Mag1 high temp wheel bearing grease or the mobil1 synthetic grease. Im basically using it to lube things like exposed bolts, nuts, and brake caliper pins, etc. Thanks for the tips.
JDMCRX
Jul 9, 2009 12:38 PM
