99Si seats in a EG
Old Feb 27, 2005 | 04:02 PM
Lmgrcivic's Avatar
Default 99Si seats in a EG
how many people have these and if so did you use the stock rails or did you use rails from some other ones.
Old Feb 27, 2005 | 04:51 PM
ReDHaTcHyGuy's Avatar
Default Re: 99Si seats in a EG (Lmgrcivic)
just swap on the Eg rails
Old Feb 27, 2005 | 05:00 PM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: 99Si seats in a EG (ReDHaTcHy97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHy97 &raquo;</TD></TR><TR><TD CLASS="quote">just swap on the Eg rails </TD></TR></TABLE>
I just bolted them in, you can drill and tap another hole. Dont get these seats, your honestly better off with your stock EG seats. Si seats have shitty leg and side bolster, its like sitting on a ******* box, invest in some del sol or integra seats.
Old Feb 27, 2005 | 05:02 PM
BlueIntegraBoy's Avatar
Default Re: 99Si seats in a EG (swapped and still slow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapped and still slow &raquo;</TD></TR><TR><TD CLASS="quote">
I just bolted them in, you can drill and tap another hole. Dont get these seats, your honestly better off with your stock EG seats. Si seats have shitty leg and side bolster, its like sitting on a ******* box, invest in some del sol or integra seats. </TD></TR></TABLE>
Yes, I have GSR seats and I sat in my friend's newly picked up Del Sol seats in his EK yesterday. WAY BETTER than stock EK seats.
Old Feb 27, 2005 | 05:11 PM
Default Re: 99Si seats in a EG (BlueIntegraBoy)
the Si seats are nicer than regular Ek seats ......
Old Feb 27, 2005 | 05:20 PM
Cain Marko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHy97 &raquo;</TD></TR><TR><TD CLASS="quote">the Si seats are nicer than regular Ek seats ......</TD></TR></TABLE>
Isnt the design of them all the same, just the fabric and patterns are different. Like I said before, Del sol or teg seats will do you just fine.
Old Feb 27, 2005 | 05:29 PM
Targa250R's Avatar
be professional
. . . but still suck pretty bad.
Old Feb 27, 2005 | 05:31 PM
Isnt the design of them all the same, just the fabric and patterns are different. Like I said before, Del sol or teg seats will do you just fine.</TD></TR></TABLE>
And the headrests
Old Feb 27, 2005 | 07:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapped and still slow &raquo;</TD></TR><TR><TD CLASS="quote">Isnt the design of them all the same, just the fabric and patterns are different. Like I said before, Del sol or teg seats will do you just fine.</TD></TR></TABLE>
no there not quiet the same they have teg style headrests.... and better support
Old Feb 27, 2005 | 07:21 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHy97 &raquo;</TD></TR><TR><TD CLASS="quote">no there not quiet the same they have teg style headrests....</TD></TR></TABLE>
They are open headrests, but not the same as Integra. They're angled too far back to rest your head on comfortably while driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and better support</TD></TR></TABLE>
Bolstering is identical to other '96-00 Civic seats.
Old Feb 27, 2005 | 07:30 PM
Cain Marko's Avatar
no there not quiet the same they have teg style headrests.... and better support</TD></TR></TABLE>
Either way I had these seats in my car and I wouldnt wish these things upon anyone for comfort or support reasons.
Old Feb 28, 2005 | 11:06 AM
Lmgrcivic's Avatar
thanks for all the support on it but I was just asking if anyone used different rails on the seats if they had them I know there not that comfortable
Old Feb 28, 2005 | 11:08 AM
balistik's Avatar
they sit crooked if you change the rails sort of. i don't know why i did it. i'm too lazy to put my stock seats back in.
Old Feb 28, 2005 | 11:49 AM
dantastic's Avatar
i just replaced my stock EG seats with EX EK seats. the EK seats sit a bit higher, but it's nice having and adjustable bottom cushion (only EX/Si EK seats have this i think?). anyways, they're 10x more comfortable than my worn out EG seats, probably b/c the foam isn't 12 years old. i got them for free, so i can't complain.
i just swapped the outside rails. i drilled an extra hole on the EK seats. the ek seats only have holes for 1 stud and 1 bolt while the EG rail has 2 studs and one bult
EG-tofu
Aug 24, 2006 05:59 PM
StalX
16
Jun 24, 2006 08:03 PM
JayDMbrent
Nov 4, 2005 08:58 AM
onfire
Sep 30, 2004 07:47 AM
pane93civhb
11
Sep 28, 2004 12:38 PM
