zc cam gear
Old Jan 20, 2002 | 06:27 PM
racedoutsi's Avatar
Default zc cam gear
hey guys whats up
im new here and I just wanted to know if integra cam gears will fit on a zc motor the black valve cover one because i want to buy adj cam gears if so what year integra if not does anyone know were they sell zc adj cam gears
thanks
Old Jan 20, 2002 | 06:34 PM
EP3_05's Avatar
Default Re: zc cam gear (racedoutsi)
I don't know for sure if they will fit but there is one way to find out...try them. I know for sure that b16 cam gears can be machined to fit under the t-belt on the zc. (b16 gears are a bit wider than the zc ones.) I also know that jun makes cam gears specifically for the zc.
Old Jan 20, 2002 | 07:41 PM
racedoutsi's Avatar
k thanks ill try that since its a d series i wonder if the civic cam gear will fit
Old Jan 20, 2002 | 11:15 PM
hondacivic4g's Avatar
Here go to http://www.upgrademotoring.com and click on performance then click on
JUN Cam sprockets (gear).That is were you'll find ZC cam gears and a price to go with them. I hope this helps
Later-cool
Old Jan 21, 2002 | 05:34 AM
markedOO1's Avatar
JUN's are a bit too much $$ IMO. I remember reading on quickhonda a long time ago about the 88-89 teg gear's 'not' fitting.... go w/ the b series gears.
Old Jan 21, 2002 | 05:47 AM
Cereal_Killer's Avatar
go with b series gears that is what i have on my ZC now from AEm. originally for a b16. and they did not need to be modified at all. yes they are a lil wider but nothing that will damage the belt.
Old Jan 21, 2002 | 07:33 PM
racedoutsi's Avatar
k thanks guys for all the help the jun ones are nice but a little pricey
I think ill go with the b16a ones
Old Jan 21, 2002 | 07:45 PM
racedoutsi's Avatar
can i use any b series cam gears or do they have to be from the b16a
Old Jan 21, 2002 | 08:09 PM
Denny317's Avatar
all b-series should work for ya. part number is 23-602 (then pick your color) for AEM. HTH.
Old Jan 21, 2002 | 08:40 PM
racedoutsi's Avatar
thanks
Old Jan 21, 2002 | 09:35 PM
dohczc's Avatar
AEM MAKES THEM!!! PRELUDE 2.0 (1988-1991) DOHC Si for the ZC DO FIT
Old Jan 22, 2002 | 06:26 AM
therealciviczc's Avatar
Default Re: zc cam gear (dohczc)
Don't expect much from gears on a ZC. They don't respond all that much to cam tuning from my experience. Maybe your results will be better than mine. We tried about 10,000 different combos, and basically in the end, the curve looked almost identical with a 3hp peak difference and a tad bit less drop off in the high rpms.
Lets put it this way, the teg ECU, header, and just about everything else I've ever done seemed to make a bigger difference than the gears. I say save your cam gear money, and buy some cams, or a turbo kit, or a subscription to hustler.
Old Jan 22, 2002 | 07:15 AM
-TJ's Avatar
-TJ
Default Re: zc cam gear (marked001)
That's because 1G integra's use 40 tooth cam gears, where the ZC and B series use 34 tooth gears. Sure they will fit, and if you find a timing belt to fit.....hmm.....cam/crank ratio is fixed at what? 2:1?
Also, it's the backspacing that is different between the B series and ZC gears. That is what needs to be machined.
Old Jan 22, 2002 | 07:44 AM
B16CivicHB's Avatar
Default Re: zc cam gear (-TJ)
so bseries cam gears fit a dohc zc? damn, i didn't know that!! what other b series parts are interchangable for the zc???
Old Jan 22, 2002 | 09:58 AM
markedOO1's Avatar
Default Re: zc cam gear (B16CivicHB)
nope...think that's it. I think maybe the head studs are the same....something like that. someone on the resource was making a complete zc rebuild guide....
Old Jan 22, 2002 | 01:43 PM
MrFatBooty's Avatar
The head studs are the same as a VW Jetta/Golf 16v engine.
Old Jan 22, 2002 | 02:36 PM
vtecjunkie's Avatar
Default Re: zc cam gear (MrFatBooty)
you dont need cam gears, dohc zc motors have self adjusting cam gears, that little silver thing on the bottom left hand corner of the valve cover, if u do see any power at all its like 1hp, your better off saving your money , an gettin some cams, jg makes good ones an so does web
Old Jan 22, 2002 | 05:03 PM
racedoutsi's Avatar
thanks so the jg and web cams are for the zc or the integra if its for the integra what year integra do i get to fit the zc
Old Jan 22, 2002 | 05:05 PM
EP3_05's Avatar
89 integra cams will work in the zc
Old Jan 22, 2002 | 05:07 PM
racedoutsi's Avatar
Default Re: zc cam gear (91civic)
thanks
Old Jan 22, 2002 | 06:38 PM
Make sure you get an aggressive cam. I'd imagine that the street cams for the 89 integra aren't any more aggresive than the ZC cams.
Old Jan 22, 2002 | 11:25 PM
AbaZ's Avatar
I have used Crower Regrind CAms on my ZC with a B-series Cam gear on the intake cam only, and it works great.. Dropped my ET's by .3
Jeff
Old Jan 23, 2002 | 08:56 AM
dohczc's Avatar
Default Re: zc cam gear (AbaZ)
The JDM ZC's cams vs. the USDM Integra's cams were more aggressive indeed. Also the pistons were dome shoped thus a little stronger too. ZC's had better flowing heads as well.
Old Jan 23, 2002 | 09:16 AM
-TJ's Avatar
-TJ
To elaborate, the JDM ZC cams have .040" more lift across the board (intake and exhaust) than the 88-89 Integra cams. I measured them.
The ZC pistons are actually exactly the same as the 88-89 integra pistons - domed, 9.5:1 CR. The 86-87 Integra pistons are the exact same as the D16A6 pistons - flat top, 9.1:1 CR
The ZC head is a different casting and is rumored to flow better. I'm not saying it does or does not, but I've never seen any data to support the rumor. Who flows HOnda heads? The casting is different because of the motor mounting system difference beween the 88+ body and the old 84-87 platform (the 86-89 Integra is built directly on the 84-87 Civic platform. Many structural parts cross over).
90CRX
Nov 15, 2003 10:58 PM
90civichbsi
Aug 27, 2003 07:58 PM
blah13
Apr 14, 2003 09:42 AM
BigDaddyRich
Aug 18, 2002 08:14 PM
REDBARON
12
Dec 3, 2001 04:00 PM
