plz anyone i neeed hlep on how to adjust my skunk2 cam gears
Old Feb 27, 2005 | 11:54 AM
94IntegraLs04's Avatar
Default plz anyone i neeed hlep on how to adjust my skunk2 cam gears
i just change my timing belt an water pump an just put in skunk2 cam gears an now the car feels like is not goin no where like it wont go over sixty it takes like five second to lunch of first
Old Feb 27, 2005 | 12:08 PM
OnDaBottle's Avatar
Default Re: plz anyone i neeed hlep on how to adjust my skunk2 cam gears (94IntegraLs04)
Did you check if your timing is correct? Check the timing on the cam gears. Make sure the crank is at tdc and so are the cams. Same thing happened when I installed my first set of cams. You can be off by a tooth or two. It didnt' want to go anywhere.
Old Feb 27, 2005 | 12:49 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: plz anyone i neeed hlep on how to adjust my skunk2 cam gears (OnDaBottle)
First make sure your timing is correct like what OnDaBottle said. If the Skunk2 gears are at their stock setting, it should drive just like stock. Something else is the problem.
Any codes?
preludejayes
Sep 13, 2007 11:37 PM
sk8rmike
Mar 29, 2005 11:25 AM
CNUKPUP
Oct 15, 2001 01:17 PM
