b18a crank gsr?
Old Feb 27, 2005 | 10:29 AM
92sireg's Avatar
Default b18a crank gsr?
I have heard u can use a b18a/b crank to stroke a gsr to a 2.0l just wondered what rods u would use the stock b18a/b? or do they have to be custom. any input would really be appreciated thanks.
92SiReg
Old Feb 27, 2005 | 10:36 AM
ExospeedAMcrx's Avatar
Default Re: b18a crank gsr? (92sireg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92sireg &raquo;</TD></TR><TR><TD CLASS="quote">I have heard u can use a b18a/b crank to stroke a gsr to a 2.0l just wondered what rods u would use the stock b18a/b? or do they have to be custom. any input would really be appreciated thanks.
92SiReg</TD></TR></TABLE>
nope it wont stroke the motor if you use an LS crank in a GSR block. There is a VERY slight diff in displacement with the LS crank but its like 30cc i think. not sure exact numbers.
If you use an LS crank, then use LS rods. it will be pretty much an LS block with a stronger Girdle.
Old Feb 27, 2005 | 12:35 PM
hybrid_vtec's Avatar
You wont increase the displacement to 2.0L unless you sleeve teh block 84mm and run either an LS or B20 crank.
GSR crank = 87.5mm stroke
LS crank = 89mm stroke
If you do it you have to use LS rods(5.394") b/c GSR rods(5.429") are too long. For the money you will probably spend you might want o just buy a B20 Block
Old Feb 27, 2005 | 04:03 PM
dfoxengr's Avatar
Default Re: b18a crank gsr? (hybrid_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid_Vtec &raquo;</TD></TR><TR><TD CLASS="quote">GSR crank = 87.5mm stroke
correction gsr crank= 87.2mm
Old Feb 27, 2005 | 05:04 PM
i thought it was 87.198 hehe.
Old Feb 27, 2005 | 08:46 PM
Default Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">
correction gsr crank= 87.2mm</TD></TR></TABLE>
I stand corrected.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">i thought it was 87.198 hehe.</TD></TR></TABLE>
Smartass!
Old Mar 10, 2005 | 05:25 AM
Shmolie's Avatar
Default Re: (hybrid_vtec)
So let me ask....If someone does this set up on an ITR, CTR or GS-R block they are getting a bigger stroke with the crank but but then down sizing on the rod, so basically you are canceling the the whole process in doing that??
If this does work, I have a free LS crank and rods sitting right next to me
jdmkidd23
Apr 13, 2008 10:33 AM
ProjectBoosted
Oct 23, 2006 10:02 AM
sircrxracer
Oct 29, 2004 07:44 AM
Nextelbuddy
11
Jun 4, 2003 03:11 PM
JUNcr-x
Apr 3, 2003 07:11 AM
