Changing headgasket, coolant went everywhere need help!!!!
Old Feb 27, 2005 | 10:17 AM
spcrxracer's Avatar
Default Changing headgasket, coolant went everywhere need help!!!!
Yeah while removing the head a bunch of coolant was poured into a couple of the cylinders in between the walls, what's the best way to get it out or should i just use some paper towels? I was thinking of using a pump device.
Old Feb 27, 2005 | 10:32 AM
Mattyg2's Avatar
were you supposed to drain the coolant before changing the head gasket?
Old Feb 27, 2005 | 10:39 AM
spcrxracer's Avatar
Default Re: (Mattyg2)
i did draing coolant but i forgot to disconnect 1 hose. its not very much. only about 1/2 full
Old Feb 27, 2005 | 11:06 AM
spcrxracer's Avatar
Default Re: Changing headgasket, coolant went everywhere need help!!!! (spcrxracer)
bump^
Old Feb 27, 2005 | 11:16 AM
jay_96teg's Avatar
hay man, not a problem. just wipe it out of the cylinders with a rag. after you put the new gasket on and all back togeter be sure to change to oil incase you got coolant in the oil pasages. just fire it up and the rest will burn off.
scaleone
Aug 24, 2016 11:11 AM
SoCalHatch
Jul 19, 2009 05:42 AM
DennisWaller
Aug 6, 2008 02:33 PM
specialedition
Jan 11, 2005 05:32 PM
