B20VTEC head gasket: OEM or Cometic??
Old Feb 27, 2005 | 10:16 AM
freakin's Avatar
Default B20VTEC head gasket: OEM or Cometic??
I just blew my head gasket in my NA B20VTEC build (11.5:1 CR) and need a replacement. I was using a Mr. Gasket, but want to use something else this time. I'm bored over a little, so I need to get one that's 84.5mm. Has anyone had luck with an OEM gasket, or would you recomend using a Cometic one? Also are there any other brands I should look at? Thanks for the help.
Old Feb 27, 2005 | 10:23 AM
na200whp's Avatar
if its an b20 block or sleeved ls use oem b20 gasket. if its a b18c block sleved ues a cometic or goldeneagle moded gasket. by b20 block was 84.5mm and the oem gasket was perfect.
Old Feb 27, 2005 | 12:51 PM
CRVTEC0WNZJ00's Avatar
Default Re: B20VTEC head gasket: OEM or Cometic?? (freakin)
I've got the Cometic 84.5mm on my CR/VTEC setup quite similar 84.5mm bore, cars never been started though because of more money issues, but I think it'll be fine.
Old Mar 1, 2005 | 06:22 AM
freakin's Avatar
So you people think that the OEM gasket should hold up? It's less than half the price of a Cometic, so I'm a little hesitant.
Old Mar 5, 2005 | 07:16 PM
freakin's Avatar
Anyone else care to comment on the head gasket choices? I'm likely ordering one next week, but I still really haven't made a decision on which one. I'm leaning a little more towards OEM, but I'm still a little hesitant.
Ohh, and to answer na200whp, my block is a B20B, bored over.
Thanks again.
Old Mar 5, 2005 | 09:03 PM
A train's Avatar
Default Re: (freakin)
cometic all the way ive used them for 3 years now and never blown a head gasket only motors. the gasket lasts longer than the motors! cometic hp's it a little thicker but and a couple more bucks but worth it!
Muckman
Apr 6, 2018 11:25 AM
Eghatchgsr8
Sep 19, 2014 02:24 PM
chasmataz
Jul 25, 2010 08:35 AM
Rheg6
20
Sep 16, 2009 07:45 PM
IEATLINT
Jun 26, 2003 12:56 PM
