I want to go type R
hey guys I have saved up enough money to get a type R swap so I want your opinion. CTR or ITR? I'm swaping it into an 02 ep3. I also wanted to know if you guys know where and who I could trust to purchase it. I would like to get a whole front clip but if not I would just take the full swap. So if you could give me some information on what I might need to swap it out and what the differences are between the integra type r and the civic type r. Is one better than the other. I would appreciate it if you guys could give me some email adresses or numbers.
thank you
thank you
the integra has 5 more Hp @220.
the question im surprised more people aren't asking is; "How do i know im buying a Integra Typer R K20A?"
both engines say "K20A" on them don't they? and they both apear to be the same externaly. the only physical difference i could say is the ITR has a power steering pump attatched to the motor, and the CTR doesn't.
www.hmotorsonline.com
they are the same motor, the 5hp different come from the exhaust, header. not the motor, so buy whatever u want...
in a stock ITR and CTR, ITR had a better exhaust system and high end power compare to the CTR which has more mid-range power
the guys above me is right
the dc5r and ep3r k20 motors are the same exact motor, just different header and exhaust
so if your planning on getting a header and exhaust anyway, get the ctr motor, it will probally be a little cheaper
both of these clips run 6-speed right? yup, just get a better exhaust system. look around. papituyo was selling a k24 for 2500 w/o tranny i heard. slap on an ITR head/ CTR... then call it a project.
Yes they are the same motors.. CTRs JDM are rare. Also if you end up buying a Civic type R motor from european civic.. that is a rsx type S engine....
The civic type r ecu from japan is PRD
the integra type R ecu from japan is PRC
When you install the motor in the car, in order to bypass the local immobilizer, you will need to ground one of the ecu e plug pins.
Nikos
Nikos
yea the difference is the exhaust and headers in the extra couple hp but in the new 05 RSX-S it has a different redline doesnt it? its like 8.3 and its been a while since i drove a 04 or older but i remember it was lower then 8.3 wasnt it? why the difference?
