FS: Turbo stuff for all types of Honda's- ECU's, boost controllers, WG's, RC injectors, etc
Old Jan 20, 2002 | 05:49 PM
Spocko's Avatar
Default FS: Turbo stuff for all types of Honda's- ECU's, boost controllers, WG's, RC injectors, etc
Hey all
Since I've just once again updated my complete turbo system, I have a few parts for sale. Most will fit any car that is turbo, although a few may be strickly for a 5th gen Lude...
- P28 ECU- already chipped from Hondata to work with their systems
- Greddy Profec-B Boost controller(black)
- Tial 35mm 2 bolt Wastegate(2,500 miles)
- 4 RC Eng. 440 cc Saturated injectors(2,500 miles)
- T4 compressor housing(.50 A/R) with .57 trim wheel
- FAL dual electric radiator fans(red)
- clear sidemarkers
I just got a new Turbonetics ceramic BB turbo, so I don't need the old compressor housing and wheel as I downsized to a different trim in the process, and I just bought an Apex AVCR boost controller so that I can vary my boost by gear. I upgraded to the Tial 40mm WG after 2 months of using it, as I had a new downpipe made and figured it would be a good time to upgrade WG's since I plan to run more than the 20 psi that the 35mm is limited to. I also need larger injectors for my system as well(720's), so my 2 month old 440cc's are useless to me now. I ordered a Fluidyne radiator too- which INCLUDES thin electric fans with it, so I no longer need my FAL ones(also 2 months old). As for my P28, I currently am using both my P28 and P72 Hondata ECU's, but I like the P72 a bit better after some tuning as it gives a bit better low end response than the P28(mainly because the P28 doesn't close the secondary intake runners at low rpms like the P72), but then again the midrange with the P28 is better due to this same fact. Like I said, it is Hondata ready-to-go, as they preogrammed it. All you need is to order you level system from them, a wiring harness and plug it in. Please email me if interested in anything- I need the money to build up my motor this winter and pay off some of the debt from this current upgrading!
Spocko_1701@hotmail.com
Old Jan 20, 2002 | 06:49 PM
Turbo_Teg's Avatar
New User
Default Re: FS: Turbo stuff for all types of Honda's- ECU's, boost controllers, WG's, RC injectors, etc (Spo
im interested in the wastegate,wat spring does it have
Old Jan 20, 2002 | 06:58 PM
01geeser's Avatar
New User
how much for the injectors?
Cornbread Jr.
Jul 28, 2004 05:55 PM
accord20o1
Jan 9, 2004 02:50 PM
