need help please (searched)
wassup all im havin a couple stupid problems please help...?
1.check engine lights on, no codes and when i turn on headlights light turns off
2.when i pull each plug wire off(misfire check) when i take off #2 the car turns off
3.water temp,fuel guages dont work only speedo works
car is a 90 sx mpfi swap wit complete si wiring I CANT FIGURE OUT WHERE A COUPLE CLIPS GO!!! any diagrams or info on wire swap will be greatful thanks in advance guys takecare
When you say "complete Si wiring", do you mean you are useing the Si engine harness? If you are then I suggest you put the DX harness back on and add the wires you need for the MPFI swap. It is always best to use the harness that came in the car and add any wires you need to make the new motor work.
You changed out the entire wire harness in the car and under the hood
First of all WHY!!!!
Second, I hope you are not surprised that you are having problems.
Third, get a Helms manuel, you are going to need it
first,cause i want it clean
second,im not surprised one bit that theres problems especially problems no ones heard of
third y would i need the helms manual
