wheel lug torque?
What is everyone torquing their Kosei K-1's too? Not sure what it should be for the Kosei K-1, but I torqued my 'new' K-1's on the Tacoma to 78 ft/lbs right now. Maybe I should bring the Torque wrench to the Auto-X event tomorrow just in case they will need tightening...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vracer111 »</TD></TR><TR><TD CLASS="quote">What is everyone torquing their Kosei K-1's too? Not sure what it should be for the Kosei K-1, but I torqued my 'new' K-1's on the Tacoma to 78 ft/lbs right now. Maybe I should bring the Torque wrench to the Auto-X event tomorrow just in case they will need tightening...</TD></TR></TABLE>
i was torquing my new k1's at 80 ft-lbs, and i nearly lost a wheel at VIR. the finish on the wheels was rubbing off around the lug, and i should've been torquing the lugs after every session but i didnt
i figure 80 is good, but just remember to torque them after every session because the wheels are new
80lbs is good enough. but i went out to sebring a while back with chinmotorsports and they torque EVERYONES to 100lbs no matter what car you have. just a heads up since you posted here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaxle »</TD></TR><TR><TD CLASS="quote">isnt it 110 or 120 for alloy wheels?</TD></TR></TABLE>
Every car and application is different. IMO, 120 ft-lbs is *way* too high.
well.......my old nissan suggested 90 ft/lbs, and i know what that feels like. i dunno exactly what i'm torquing to, but by feel it is about 70-80lbs for my k-1's on the miata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy »</TD></TR><TR><TD CLASS="quote">I got lightweight racing lugs and they are rated at 40lbs - I tested to see if it would go over, and it stripped... </TD></TR></TABLE>
40 Lbs?! Seems like that would be scary to me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.CACO »</TD></TR><TR><TD CLASS="quote">
40 Lbs?! Seems like that would be scary to me...</TD></TR></TABLE>
It is! I'm getting new ones... But no problems at 40pnds... Then again you could drive around with no lugs just don't take hard turns...
It's generally supposed to be around 80 lb-ft for steel wheels, and around 100 lb-ft for aluminum wheels.
It doesn't have to be exact; tightening lugs isn't rocket science. I personally just tighten them as far as they'll turn with my lug wrench. They never come loose on me . . .
120 pounds is ford f-150 specs
80
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">It doesn't have to be exact; tightening lugs isn't rocket science. I personally just tighten them as far as they'll turn with my lug wrench. They never come loose on me . . .</TD></TR></TABLE>
i dont torque my wheels to prevent them from falling off... i do it so every nut is clamping with the same force therefor not warping brake rotors.
80
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">i dont torque my wheels to prevent them from falling off... i do it so every nut is clamping with the same force therefor not warping brake rotors.</TD></TR></TABLE>
I have never had a warped brake rotor from improperly tightened lugs on any of my vehicles (I honestly don't even know how this is possible). Nor have I ever heard of anyone complaining of this problem when tightening by hand - only when using an impact gun.
Besides, when tightening by hand, I can usually get them close enough that the difference in torque between each lug is negligible.
