throttle body seems to get stuck, b18c5 aebs manifold with jg tb into a gsr
Old Feb 26, 2005 | 08:39 PM
pearlwhitecrx's Avatar
Default throttle body seems to get stuck, b18c5 aebs manifold with jg tb into a gsr
I believe I am using an b16 throttle cable and bracket with the aebs manifold and a 65mm jg tb
when i first step on the gas and let go its fine, then when i try to step on the gas again its as if something is holding it back from opening the tb and i have to force the pedal down i hear a pop noise and i can accelerate normal again. My question is does it sound like the tb is jus dirty, i need to change the tb pulley? or what
its a b18c1 into a gsr, i might be using the stock gsr throttle cable im not sure.
any suggestions????
Old Feb 26, 2005 | 08:48 PM
lemongreenhatch's Avatar
Default Re: throttle body seems to get stuck, b18c5 aebs manifold with jg tb into a gsr (pearlwhitecrx)
my friends jg throttle body does the same thing i heard there tb's are known to get stuck
Old Feb 27, 2005 | 02:27 AM
Mr_GaBIG's Avatar
Default Re: throttle body seems to get stuck, b18c5 aebs manifold with jg tb into a gsr (poorman's-allmotor)
You need to adjust the throttle plate.
The screw with the spring needs to be adjusted to prevent the plate catching the throttle body.
Old Feb 27, 2005 | 07:34 AM
asubennett's Avatar
Default Re: throttle body seems to get stuck, b18c5 aebs manifold with jg tb into a gsr (Mr_GaBIG)
It is not really the plate that is catching. Look at the back of the TB wheel. I bet it is moved to far inward on the shaft and is catching against the main body of the TB itself. on the underside of the wheel there should be a tiny screw that you can loosen to pull the wheel slightly backwards off the shaft.
Cpt Ben
Apr 5, 2007 07:18 PM
redGSRguy
Feb 6, 2006 08:58 AM
clutcher
Apr 21, 2005 05:25 PM
