Camber kit install
Old Jan 20, 2002 | 05:01 PM
TexTeg's Avatar
Default Camber kit install
Is there a do it yourself for a camber kit install anywhere for a 98 integra ls 2 dr? If not, could someone lay out how to install it? Or is this something to give to a shop? I'm just wanting to install it not do the adjusting (give that to NTB for that). NTB said they could install it, but its 160 bucks for the R and L camber which is something I don't want to spend. Thanks
Old Jan 20, 2002 | 05:37 PM
WRXRacer111's Avatar
Default Re: Camber kit install (TexTeg)
What kind of camber kit do you have? There are many different kinds. I could tell you how to install a K-Mac adjustable balljoint camber kit, but that won't be of very much help if yours is not similar.
Old Jan 20, 2002 | 05:40 PM
Gump's Avatar
http://www.geocities.com/kingmantis81/rearcamber.html
used this on my car and it works just as good
Old Jan 20, 2002 | 06:25 PM
ingrate's Avatar
25 Year Member
Default Re: Camber kit install (xlr8 si)
The progress kit was pretty easy to install. it replaces the upper control arm joints
Old Jan 20, 2002 | 08:42 PM
TexTeg's Avatar
Default Re: Camber kit install (WRXRacer111)
Its an Ingalls camber kit for the front two. Regretably, the front camber looks a bit more complicated than the bolts/washers for the rear but thanks nonetheless. Anyone installed this camber on the front?
Old Jan 21, 2002 | 09:25 AM
TexTeg's Avatar
anyone?
actek23
Suspension & Brakes
Oct 26, 2007 05:53 AM
down_the_hatch
Feb 8, 2005 12:51 AM
N-tegra
Mar 15, 2004 04:44 PM
ForcedAccord
Mar 1, 2002 12:00 PM
