how to check IAC valve malfunction
Old Feb 26, 2005 | 05:13 PM
dayaftertomorrow's Avatar
Default how to check IAC valve malfunction
2001 gsr misfires in all 4 cylinders. Somone told me to start the engine and hold the accelerator steady at 3,000 rpm until the cooland fan comes on. Then disconnect the electrical connector to the IAC valve. The engine idle spped should drop or stall. So I did what they told me and there is no change of the engine idle speed. Does it prove that the IAC valve malfunction? Need some help. Thanks
Old Feb 26, 2005 | 09:24 PM
virusiidx's Avatar
there should be a change, usually it would go down to about 450rpm. got any cel codes?
Old Feb 26, 2005 | 10:11 PM
Default Re: (virusiidx)
No change in idel speed after unplug the electrical connector to the IAC valve. Idel speed stays at 900 rpm. It throws a code after unplug the connector. No code with connector intact and only got the 91, 93 misfiring code. So is it the IAC valve defected or should I replace the IAC valve? Thanks
Michael_Robinso
Dec 3, 2011 10:42 AM
yoffer
May 31, 2007 11:54 AM
Dc_Ek
Dec 8, 2005 03:37 PM
niceguy12
Jan 8, 2005 02:52 PM
92eg6
16
Apr 15, 2004 10:35 AM
