Fuel Pressure = 93psi
Old Feb 26, 2005 | 04:39 PM
HatchBox's Avatar
Skoobie no more...
Default Fuel Pressure = 93psi
Well i posted in the Tech room but i ment to post here.
Someone said I might have a pinched return line. Any way to check that?
Also im hoping to get some feedback from those who have the 255walbro.
1990 civic hatch
b16-stock
UPDATE:
Switched the guage to the other fitting on the fuel filter and i installed a new b&m fpr.
no change
Modified by HatchBox at 3:36 PM 2/27/2005
Old Feb 26, 2005 | 04:51 PM
crxgator's Avatar
Default Re: Fuel Pressure = 93psi (HatchBox)
broken guage?
Old Feb 26, 2005 | 04:54 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Fuel Pressure = 93psi (crxgator)
brand new
when i turn car off it sticks at 31 psi
Old Feb 26, 2005 | 04:55 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">brand new
there's your answer...
Old Feb 26, 2005 | 04:57 PM
HatchBox's Avatar
Skoobie no more...
it should hold pressure when the sytems off?
Old Feb 26, 2005 | 05:02 PM
crxgator's Avatar
35-41 psi is what it should be at idle, and im pretty sure it would be at 0 when off since nothing is pumping the fuel...looking at your picture you see the guage has a broken face, im pretty sure that the guage is messed up...when you start it and run it whats happening? im sure at 91 psi, your going to have fuel spew out everywhere since thats double stock... if it would even run at all...i think you have the guage on the wrong side btw...
Old Feb 26, 2005 | 05:09 PM
GSRCRXsi's Avatar
actually the system does hold pressure. i have a fuel guage on my car and when its running and i turn it off the fuel pressure stays the same. it will slowly decrease over time. but mine was always the same presure reading right before i shut it off as opposed to right after.
Old Feb 26, 2005 | 05:10 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">35-41 psi is what it should be at idle, and im pretty sure it would be at 0 when off since nothing is pumping the fuel...looking at your picture you see the guage has a broken face, im pretty sure that the guage is messed up...when you start it and run it whats happening? im sure at 91 psi, your going to have fuel spew out everywhere since thats double stock... if it would even run at all...i think you have the guage on the wrong side btw...</TD></TR></TABLE>
Sytem should stay at pressure when engine if off.
The guage is liquid filled, not broken
Old Feb 26, 2005 | 05:35 PM
Sikocivic's Avatar
I have never seen the gauge put on that way, put it on the other fitting and see what it says then.
Old Feb 26, 2005 | 05:39 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Fuel Pressure = 93psi (Sikocivic)
heh i just figured that it would read the same in the whole system, and i thought you need the service bolt.
oh well brb
Old Feb 26, 2005 | 05:55 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote"> put it on the other fitting and see what it says then.</TD></TR></TABLE>
Just switched them and im getting the same reading. Car barely runs still
Old Feb 26, 2005 | 05:59 PM
IpwnN00bs's Avatar
hehe i'd help if people weren't ******** (nothing to do with anyone here)... im me if you want help.
Old Feb 26, 2005 | 06:01 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Fuel Pressure = 93psi (nismo240sx1)
Old Feb 26, 2005 | 06:07 PM
jdmcrx34's Avatar
i have my b&m guage set up the same way as in your pic and it runs fine with my b16 crx.do you have a fuel pressure regulater? if you do adjust it down or try swapping the stock fuel regulator for another, it might help.
Old Feb 26, 2005 | 06:09 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Fuel Pressure = 93psi (jdmcrx34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx34 &raquo;</TD></TR><TR><TD CLASS="quote">i have my b&m guage set up the same way as in your pic and it runs fine with my b16 crx.do you have a fuel pressure regulater? if you do adjust it down or try swapping the stock fuel regulator for another, it might help.</TD></TR></TABLE>
I just got the regulater today. Havent had a chance to put it in.
I would think that there wouldn be that much adjustablity. I mean when im 50-60PSI above stock you have to think there must be something else
Old Feb 26, 2005 | 06:15 PM
senpai's Avatar
what was the running condition of the vehicle BEFORE gauge install?
Old Feb 26, 2005 | 06:17 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Fuel Pressure = 93psi (senpai)
Hard start/ little rough idle
now its
Hard start/crappy almost wants to die idle
I will try it tommorrow with no guage.
Old Feb 26, 2005 | 07:44 PM
crexer's Avatar
you should have the FPG on the opposite fuel line from whats in the pic. Also im sure that your FPR has taken a dump. Let us know how your new one works
Old Feb 26, 2005 | 08:06 PM
jdmcrx34's Avatar
Default Re: Fuel Pressure = 93psi (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">you should have the FPG on the opposite fuel line from whats in the pic. Also im sure that your FPR has taken a dump. Let us know how your new one works</TD></TR></TABLE>
could you explaine why becaues mine is set up the same way as his. thanks.
Old Feb 26, 2005 | 08:30 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx34 &raquo;</TD></TR><TR><TD CLASS="quote">could you explaine why becaues mine is set up the same way as his. thanks.</TD></TR></TABLE>
U want the gauge to be mounted after the filter to get a truer psi reading.
Wow 90+ psi is fawkin high. Put on the new regulator and turn it down. People always think liquid filled gauges are broken (cracked face), its funny.
Old Feb 26, 2005 | 08:35 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Fuel Pressure = 93psi (fourthgenhatchB17)
yea im just afraid that its not the fpr but a clog/pinch in the return line
Old Feb 26, 2005 | 08:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">yea im just afraid that its not the fpr but a clog/pinch in the return line </TD></TR></TABLE>
Have u checked the engine bay return line?
Old Feb 26, 2005 | 09:02 PM
PURPLETERROR aka BIGMATT's Avatar
Check your return line at the tank, I am running the same pump in my hatch, had the same problem right after i installed my new fuel tank and pump. The retun right by my tank got pinched. Good luck
Old Feb 26, 2005 | 09:18 PM
abnaasefmb's Avatar
Default Re: Fuel Pressure = 93psi (PURPLETERROR)
trun the car on and pull the fuel pump fuse and let the car die the fuel pressure should read almost 0. if you can't pull the fuse (i don't even know if there is one) take out the back seat and disconect the fuel pump while its running should end up with the same thing 0 psi.
Old Feb 27, 2005 | 09:41 AM
HatchBox's Avatar
Skoobie no more...
Default Re: Fuel Pressure = 93psi (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">trun the car on and pull the fuel pump fuse and let the car die the fuel pressure should read almost 0. if you can't pull the fuse (i don't even know if there is one) take out the back seat and disconect the fuel pump while its running should end up with the same thing 0 psi.</TD></TR></TABLE>
It goes to 0 when ever i release system pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">Check your return line at the tank, I am running the same pump in my hatch, had the same problem right after i installed my new fuel tank and pump. The retun right by my tank got pinched. Good luck </TD></TR></TABLE>
its either that or the return line somehow got clogged...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
Wow 90+ psi is fawkin high. Put on the new regulator and turn it down. </TD></TR></TABLE>
Just put a new b&M fpr on and im still getting the same results
