D15b2 what can be done?
I don't have the coin for an engine swap what can be done with this D15 engine? anything???? i'm guessing it's a lost cause and I should sell it but it only has 100k's on it,
You can do the multipoint fuel injection swap. This will allow you to run 4 fuel injectors instead of two that you are running currently. You then should be able to take advantage of mods more efficiently. The DPFI system doesn't respond to mods very well. After that you can do anything...all motor/turbo etc
Well you should just save what you can towards a swap. I wouldn't invest any money into that motor. At the very least get a D16A6 or a D16Z6, both are relatively affordable, and can be made to make your car scoot along a little faster. My 2 pennies.
cyber13
cyber13
I've got a few questions.I've found a 92 DX HB to use as a donor.But , I have a 91 (STD) HB .I know I need the Intake manifold, throttle body,Fuel rail and (something else you wrote TPS ???)Is there any thing else?I know I need a new ECU since I'm going to be changing from a DPFI to a MPFI and I'm also assuming I need to do some rewiring or do I ?Any any info would be helpful.By the way the Head has already been taken, but is there any internals I can use?
Thanks-HC4G
Thanks-HC4G
I don't know if this is going to help but the issue of IMPORT TUNER...the one with the orange civic and the girl wearing a blue shirt on the outside, I think it was the Sept. 2001 issue tells you what to do so that you can swap in a MPFI system in. Including the wiring I think.
ive made a post on exactly how to do this swap its the best five dollars ive ever spent haha i got all the parts for 5 dollars https://honda-tech.com/zerothread?id=111104
vtville
Nov 26, 2009 11:15 AM
GarageAlchemist
Feb 23, 2006 04:12 AM
Playa_FL
33
Jan 16, 2005 02:31 PM
