mini me died today...any ideas?
so my d15z1/d16z6 mini me was running great for the last few days and then today i was driving...out of no where it starts to sputter and then dies...im going like 45 down a hill and i popped the clutch and it'd start up, and a **** load of black smoke came out...
Well, I got it to a parking lot where I checked the timing and it was still on. I could start it but it would only idle....if i would try to rev it up at all, it would backfire and pretty much die out
it kind of sounds like it is running on 3 cylinders only...
yeha so anyideas would help, as i said, i check the timing belt, that was still aligned correctly, no CELs other than the speed sensor (17) but that has been there for a long time.
thanks
thanks
When I flick the key on, i can hear the fuel pump, i gotta pull the damn car into the garage and then i'll pull the fuel line and see if im getting fuel pressure.
I'll also do a compression test, i have a new set of spark plugs for it too.
i'll be back shortly with information
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">Take off the dist cap and make sure the rotor is still on.</TD></TR></TABLE>
to you sir.
There is another thread about a d16a6 that i read prior to posting and this was the issue. When I read it i was like...nooo not me.. (I personally never touched this dist, it came on one of the motor's that i've bought and I put it on not thinking about it. Well I pull the cap off, and the rotor is spinning. So yeah. No rotor screw = ownage. Atleast I'm hopeing that is all it is.
#1 cylinder spark plug was dry. while 2,3,4 were all wet. I'm replacing w/ new spark plugs and might possibly switch that injector. Whenever I drive it, it will kind of sputter in low rpms, but once I get into higher rpms it drives fine. I think it mihgt be a fucked up injector.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellon »</TD></TR><TR><TD CLASS="quote">A compression test is in order.. but it sounds like a fuel problem. </TD></TR></TABLE>
#1 = 152
#2 = 154
#3 = 150
#4 = 147
I'm going to redo #4 when I go backoutside.
I know those numbers probably seem low overall, but this is a d15z1/d16z6 so the compression is like 7.7:1 or something like that =/
I will let you guys know if it is working after i replace the screw to the rotor.
to you sir. There is another thread about a d16a6 that i read prior to posting and this was the issue. When I read it i was like...nooo not me.. (I personally never touched this dist, it came on one of the motor's that i've bought and I put it on not thinking about it. Well I pull the cap off, and the rotor is spinning. So yeah. No rotor screw = ownage. Atleast I'm hopeing that is all it is.
#1 = 152
#2 = 154
#3 = 150
#4 = 147
mhcmm87
Sep 20, 2018 07:03 AM
hmtcrxsir
13
Jan 19, 2008 06:06 PM
93civicd16z
Feb 22, 2006 10:10 AM
