82mm B16 safe?
Old Feb 26, 2005 | 01:15 PM
JDMlyfestyle's Avatar
Default 82mm B16 safe?
in a serious dilema to use the Tech43 stroker kit for 82mm or 81.5 mm.
Would the stock sleeves be able to handle 82mm without any complications? or would i need a block gaurd for added insurance.
Also i want to use a GE block gaurd how is the reputation on that. ive heard some horror stories for blockgaurds in the past.
thanks guys
Old Feb 26, 2005 | 05:02 PM
Mike K's Avatar
Default Re: 82mm B16 safe? (JDMlyfestyle)
yea, stock sleeves can handle 82mm, but don't go FI or N2O.
Old Feb 26, 2005 | 05:35 PM
Rocket's Avatar
Default Re: 82mm B16 safe? (Mike K)
GE Block Guard works great.
BE SURE TO INSTALL BLOCK GUARD BEFORE HONING THE CYLINDERS.
Old Feb 26, 2005 | 11:37 PM
Default Re: 82mm B16 safe? (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">GE Block Guard works great.
BE SURE TO INSTALL BLOCK GUARD BEFORE HONING THE CYLINDERS.</TD></TR></TABLE>
may i ask why?
Old Feb 26, 2005 | 11:53 PM
Mike K's Avatar
my guess would be that when you hammer the block guard in, it ever so slightly distorts the cylinders.
block guards are a waste of time, IMO.
but then again, i havent seen one since '01.. and it was a NuFormz pos. i've been out of the game for a while, so don't take my post to heart. for all i know, rocket makes a titanium coated triple flux capacitor ion block guard that works awesome.
but as for me, i've never used one and i've bee fine.
Old Feb 27, 2005 | 10:12 AM
can anyone back up that info?
Old Feb 27, 2005 | 11:26 AM
asubennett's Avatar
Default Re: (JDMlyfestyle)
For N/A I wouldn't install a block guard. I don't think you will see the extreme cylinder pressures that you would on an FI application. Seems a bit overkill to me unless your planning on spinning this thing to 9,500rpm +
Old Feb 27, 2005 | 12:08 PM
Im gonna take it til it stops making power
Old Feb 27, 2005 | 12:15 PM
asubennett's Avatar
Well thats a given. What cams, IM and headwork do have. You should know about where it is going to stop making power.
Honestly I would ditch the block guard and apply the $100 towards something more productive. There are much better insurance policys to be had for $100. Try ARP main studs and ARP rod bolts.
Or use it towards Hondata S100. Or use it towards an hour on a dyno. etc....
Old Feb 27, 2005 | 12:18 PM
Mild port and polish on a b16 head. BC spec 3 +.. GSXR 1000 ITB's RC 370cc Injectors with Crome
Old Feb 28, 2005 | 11:00 AM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">
may i ask why?</TD></TR></TABLE>
To avoid bore distortion.
Old Feb 28, 2005 | 11:37 AM
ok so i would be safe with a 82mm bore with 12:1 compression with a GE block gaurd
Old Feb 28, 2005 | 12:06 PM
Rocket's Avatar
Yes.
jeremiah87
Nov 19, 2008 02:17 PM
marksturboek
Apr 23, 2006 03:02 PM
s2kdre
Apr 29, 2005 07:21 PM
anothersickhatch
Jun 26, 2004 01:02 PM
menkio
Jun 12, 2004 10:37 AM
