Wiring Diagram
Yes I did a search so if this was descused somewhere else, sorry...
anyway I need the wiring diagram for the Headlits/Turn signals basicly all external lighting for a '89 CRX I need to wire my turn signals and the wirews are all torn up on the front of my car. one head light works and both brights work so I need to trace the wires back. thanks for the help
Go to hondahookup.com and click on Manuals on the left side.. In there look for the crx manual and in that youll see wiring diagrams for everything in your car..
thanks alot that diagram will be a great help trying to get the one headlight that dosent turn on to turn on. but I also need to get both frount blinkerse working as well
the ecu's plugs conects to the main wiring harness with a plug? the reason im asking this...i just bought a89 'rex and i was moving the carpet from the ecu area, in WHAM, big surprise all the wires coming from the ecu plug were loose, chopped out, and now i had no idea wich one is one...i cant even follow the color of each wire, because they has been choppedwith diferent colors....i dontknow if exist kind of plug from the ecu to the main wiring harness? i got a pr3 ecu, obd0
thnkx
thnkx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xyzalvarez »</TD></TR><TR><TD CLASS="quote">the ecu's plugs conects to the main wiring harness with a plug? the reason im asking this...i just bought a89 'rex and i was moving the carpet from the ecu area, in WHAM, big surprise all the wires coming from the ecu plug were loose, chopped out, and now i had no idea wich one is one...i cant even follow the color of each wire, because they has been choppedwith diferent colors....i dontknow if exist kind of plug from the ecu to the main wiring harness? i got a pr3 ecu, obd0
thnkx</TD></TR></TABLE>
Go to the junkyard and try and find the exact year and model car there, Cut the ecu harness and take it home so you have a reference of what color wires go where.. If you dont have enought wire left to solder on then depin the wire from the junkyard harness and put into yours and solder..
REDRAGON RR
Mar 5, 2007 05:39 PM
series3racer19
Mar 12, 2005 11:47 PM
