How do you take the plastic cover off the Steerinf column
Old Feb 26, 2005 | 11:52 AM
Soccerking3000's Avatar
Default How do you take the plastic cover off the Steerinf column
as stated in the topic how do you take off the steering column cover piece, i need to get to the ignition so i can solder in the wires for my turbo timer, thanks in advance
Old Feb 26, 2005 | 11:55 AM
_Spugen_'s Avatar
Look under the column there are like three screws under there..
Old Feb 26, 2005 | 11:57 AM
Default Re: (SpugenEG2)
ya it ook those out but the thing wont come off, is it supposed to seperate or something, i dont want to break it
Old Feb 26, 2005 | 11:58 AM
R Thizzel's Avatar
Default Re: (Soccerking3000)
i think it should have clip in things on each side if im not mistaken. maybe wiggle it around and mess with it for a little bit
Old Feb 26, 2005 | 11:59 AM
Default Re: (R Thizzel)
i might have to i dont want to break it is all
Old Feb 26, 2005 | 12:11 PM
R Thizzel's Avatar
ht well i jus looked at mine there is the 3 screws and after those come out u gotta press in right above the ignition and the same on the other side since the clips are on the inside
Old Feb 26, 2005 | 12:12 PM
_Spugen_'s Avatar
yea just pull it apart.
Old Feb 26, 2005 | 06:13 PM
ya i ended up just ripping it apart lol
Old Feb 26, 2005 | 06:45 PM
eK9aT10pSi's Avatar
there are plastic clips that join both of them. just pull with ease.
Old Feb 26, 2005 | 07:55 PM
Default Re: (eK9aT10pSi)
ya they no longer exist...
Old Feb 27, 2005 | 09:52 PM
R Thizzel's Avatar
thats the i dont give a **** attitude i love to see
Old Feb 27, 2005 | 09:58 PM
litterbox's Avatar
I am a (Trial User) Army
Will you be able to reuse them?
Old Feb 27, 2005 | 10:01 PM
Street Ghost's Avatar
Default Re: (litterbox)
i had to pull mine apart when i did my steering wheel. felt like i was gonna break the damn thing.
Old Feb 27, 2005 | 10:28 PM
civicrtype2's Avatar
they have a whole post on every topic dealing with interior/exterior/engine questions and applications at the top. You should check it out. I wouldnt of put my new CTR wheel on if it werent for that guy (and yes I might of ripped off the damn clips for the plastic cover) Luck I didnt and followed instructions.
good ish man!
Old Feb 28, 2005 | 07:01 AM
ironlung78's Avatar
Default Re: (civicrtype2)
chances are even if you try to be careful to not break the clips, they usually do break..
Old Feb 28, 2005 | 07:20 AM
Ricey McRicerton's Avatar
Default Re: (sidesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi &raquo;</TD></TR><TR><TD CLASS="quote">chances are even if you try to be careful to not break the clips, they usually do break..
Sadly, I've broken more panels and clips trying to baby them off than I have just grabbing and yanking the **** out of them.
Old Feb 28, 2005 | 09:12 AM
Default Re: (Ricey McRicerton)
i knew they were there but just said **** it, somehow they still hold the 2 pieces together, so i could careless if they are broken lol
ChevelleSSLS6
May 6, 2025 03:00 PM
jbell
Honda S2000
16
Sep 18, 2008 06:26 PM
PetroGuyX
Sep 13, 2003 04:53 PM
Dacalac
Aug 7, 2003 12:00 PM
dLo GSR-stolen-now-WRX
Nov 6, 2002 12:41 PM
