ECU code #5 and #8
Just did a d16z6 swap into my CRX HF. Im staying obd0 so im using the PM6 ECU, im getting codes 5 and 8. I know that the code 5 is Intake Pressure, and code 8 is TDC Sensor. How do i fix these codes? Ive checked the distributor for the code 8 and everything is all good. I switched in a good ECU (that I KNEW FOR A FACT was good) and im still getting the codes. How do i fix these? Im ready for my car to get running right. Thanks in advance
dont know much about the #5 code.. but the code 8.. i assume you put an ohm meter on the a and b pin and it checked out ok? ~350-550 ohms? cause if those checked out ok, then check the same wires on the other side of the plug and see if you have continuity there. if you do.. then you should be good, but if you dont, then it might be your harness. also to save some time, if you have access to another distributor, you might swap that in.. just to see.. it might just be worth it to get a new distributor all together.. they can be had on ebay for 149 shipped. good luck man.
JustAnotherRex
17
Jul 9, 2007 04:15 PM
